The system provides you with two methods to rebuild topology to keep all topology links up-to-date when you network change.
▪Auto-rebuild topology through a discovery or benchmark task
IPv4 L3 Topology is built automatically after Live Network Discovery and scheduled discovery tasks. You can also customize whether to build IPv4 L3/IPv6 L3/L2 topology and L3 VPN tunnel automatically during a scheduled benchmark task. See Benchmark Task Settings for more details.
The accuracy of L2 topology relies on IPv4 L3 topology, so it is recommended to build them together during a benchmark task. The rebuilt-topology is calculated based on existing data in the Current Baseline.
2.In the Domain Management page, select Topology Link Manager from the start menu.
3.In the Topology Link Manager, point to the topology entry and click the
icon to select Rebuild Topology from the drop-down menu.
Note: The topology links in the manually created zones cannot be updated by running a benchmark task or Qapp.
