Configure Private Network Settings
Network engineers usually have their private access credentials to make changes on specified devices. Private Network Settings can be used to record and manage these private access credentials in the system. These private access credentials in the system are used when Managing Network Changes.
To configure private network settings, do the following:
Note: If the Use shared credential and shared privilege credentials option is selected for Network Change Credential Management, the Private Network Settings will not be accessible.
2.In the Domain Management page, select Operations > Advanced Tools > Tune Private CLI Settings from the quick access toolbar.
3.In the Tune Private CLI Settings tab, click Private Network Settings and enter the necessary private credentials under the related tabs. These credentials will be only available to the user who configure them.
Configuring Telnet/SSH Login Credentials
Configuring Private Key
Configuring Privilege Login Credentials
4.Tune the access credentials to make sure they can work. See Tuning Private CLI Settings for more details.
1)Select the Telnet/SSH Login tab.
2)Click Add to open the Telnet/SSH Login dialog box.
3)Select the authentication method, enter or select the non-privilege login credentials and click OK.
Tip: For SSH login method, if there is no available private key, you can select New in the Private Key field to add one. See Configuring Private Key for more details.
Repeat step 2) and step 3) to add more entries if required.
The following SSH private key types are supported in the system to access your network devices:
SSHv1 RSA key
SSHv2 RSA key
SSHv2 DSA key
1)Click the Private Key tab.
2)Click Add to open the Private Key Setting dialog box.
3)Enter the alias and click Browse to import your SSH private key file.
4)Enter the passphrase and confirm if your private key is encrypted.
5)Click OK.
Repeat step 2) and step 5) to add more entries if required.
The credentials for privileged mode login on live devices. With these credentials, the system can issue CLI commands on devices and change their configurations.
1)Click the Privilege Login tab.
Note: The Privilege Login tab is available only if the private privilege credentials option is selected for Network Change Management.
2)Click Add to open the Privilege Login dialog box.
3)Enter the access credentials and click OK.
