▪Service Monitor Agent will be installed with all Linux components and it has dependencies on the third-party package zlib-devel readline-devel bzip2-devel ncurses-devel gdbm-devel xz-devel tk-devel libffi-devel gcc. Run the rpm -qa|grep -E "zlib-devel|readline-devel|bzip2-devel|ncurses-devel|gdbm-devel|xz-devel|tk-devel|libffi-devel|gcc" command to check whether it has been installed on this Linux server. If it has not been installed yet, you can choose either option below to install the dependencies:
oOnline Install: run the yum -y install zlib-devel readline-devel bzip2-devel ncurses-devel gdbm-devel xz-devel tk-devel libffi-devel gcc command to install it online.
2.Run the cd /opt/netbraintemp10.1 command to navigate to the /opt/netbraintemp10.1 directory.
3.Download the installation package.
▪Option 1: If the Linux server has no access to the Internet, obtain the netbrain-servicemonitoragent-linux-x86_64-rhel-10.1.tar.gz file from NetBrain and then upload it to the /opt/netbraintemp10.1 directory by using a file transfer tool.
wget <download link> command under the /opt/netbraintemp10.1 directory to directly download the netbrain-servicemonitoragent-linux-x86_64-rhel-10.1.tar.gz file from NetBrain official download site.
4.Run the tar -zxvf netbrain-servicemonitoragent-linux-x86_64-rhel-10.1.tar.gz command under the /opt/netbraintemp10.1 directory to extract installation files.
[root@localhost netbraintemp10.1]# tar -zxvf netbrain-servicemonitoragent-linux-x86_64-rhel-10.1.tar.gz
ServiceMonitorAgent/
ServiceMonitorAgent/config/
ServiceMonitorAgent/config/setup.conf
ServiceMonitorAgent/install.sh
5.Run the cd ServiceMonitorAgent/config command to navigate to the config directory.
6.Modify the parameters in the setup.conf file located under the config directory according to your environment and save the changes. For how to modify the configuration file, refer to Editing a File with VI Editor.
[root@localhost config]# vi setup.conf
# IE API Url, for example: http://ie.netbrain.com/ServicesAPI
# Attention please: /ServicesAPI is a fixed suffix
Server_Url=http://10.10.3.141/ServicesAPI
# Authentication Key to be used to communicate with Web API server.
# Note: please ensure this key must be the same as the API key created on Web API server.
Server_Key=Admin1.#
# LogPath is used to store log files for Servicemonitor.
# This directory must be at least a second level directory and used exclusively for this purpose.
LogPath=/var/log/nbagent
# Whether to enable verifying Certificate Authority (CA): By default, it is disabled.
yes indicates enabled; no indicates disabled.
# Note: To enable the verifying CA, it is needed to change configuration of the Web Server.
CA_Verify=no
# CertAuth specifies the CA file source path. Below CA file will be copied to folder /etc/ssl/netbrain/nbagent
CertAuth=/etc/ssl/cacert.pem
7.Run the cd .. command to navigate to the ServiceMonitorAgent directory.
8.Run the ./install.sh script under the ServiceMonitorAgent directory to install the Service Monitor Agent.
1)Read the License Agreement, and type YES.
2)Type I ACCEPT to accept the License Agreement. The script starts to install Service Monitor Agent.
[root@localhost ServiceMonitorAgent]# ./install.sh
Please read the End User License Agreement (“EULA”) for the license type (perpetual or subscription) purchased in the order form at
https://www.netbraintech.com/legal-tc/ carefully. I have read the subscription EULA, if I have purchased a subscription license, or the
perpetual EULA, if I have purchased a perpetual license, at the link provided above. Please type “YES” if you have read the applicable EULA
and understand its contents, or “NO” if you have not read the applicable EULA. [YES/NO]: YES
Do you accept the terms in the subscription EULA, if you have purchased a subscription license, or the perpetual EULA, if you have purchased
a perpetual license? If you accept, and to continue with the installation, please type "I Accept" to continue. If you do not accept, and to quit
the installation script, please type "CANCEL" to stop. [I ACCEPT/CANCEL]: I ACCEPT
Preprocessing SUCCEEDED
Starting to install Service Monitor Agent ...
Starting to system checking...
Collecting system information...
Collecting system information SUCCEEDED.
System checking SUCCEEDED.
Starting to configuration parameters checking...
Configuration parameters checking SUCCEEDED.
Start dependencies checking...
Dependencies checking SUCCEEDED.
Obtaining file:///usr/share/nbagent
Installing collected packages: agent
Running setup.py develop for agent
Successfully installed agent
You are using pip version 18.1, however version 19.0.3 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Configuration parameters updating SUCCEEDED.
Starting to permission assigning...
Permission assigning SUCCEEDED.
Starting to deamon setting...
Deamon setting SUCCEEDED.
Successfully installed Service Monitor Agent. Service is running.
INFO: Backing up uninstall.sh SUCCEEDED
INFO: Successfully installed Service Monitor Agent.
9.Run the systemctl status netbrainagent command to verify whether its service starts successfully.
[root@localhost ~]# systemctl status netbrainagent
netbrainagent.service - NetBrain Service Monitor Agent Daemon
Loaded: loaded (/usr/lib/systemd/system/netbrainagent.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2019-05-04 23:19:09 EDT; 5min ago
Main PID: 4520 (python3)
Memory: 73.5M
10. (Only required if you have configured DNS connection when installing MongoDB/Elasticsearch/Redis/RabbitMQ). To make the Server Monitor Agent can still detect and monitor its service, add the customized port number to the corresponding configuration file.
Server Name |
File Name |
MongoDB |
mongodb.yaml |
Elasticsearch |
elasticsearch.yaml |
RabbitMQ |
rabbitmq.yaml |
Redis |
redis.yaml |
Front Server |
fs.yaml |
License Agent |
license.yaml |
Example: If you use FQDN during MongoDB installation, do the following:
1)Run the cd /etc/netbrain/nbagent/checks command to navigate to the checks directory.
2)Add the following DNS info to the mongodb.yaml file, and save the changes. For how to modify the file, refer to Editing a File with VI Editor.
Note: Follow the text format in the example strictly, including alignment, punctuations, and spaces.
init_config:
instances:
- name: default
dns: mongo2.cloud.netbraintech.com
Example: If you installed multiple MongoDB instances on one server with different ports and service names (e.g,, instance 1 with service name mongod and port 27017; instance 2 with service name mongod2 and port 27018), do the following:
2)Add the customized port number to the mongodb.yaml file, and save the changes. For how to modify the file, refer to Editing a File with VI Editor.
Note: If fully qualified domain name (FQDN) is used when installing MongoDB on this machine, add dns:<MongoDB FQDN> to the mongodb.yaml file.
Note: Parameter name refers to the MongoDB service name.
init_config:
instances:
- name: mongod
port: 27017
- name: mongod2
port: 27018
Parameter |
Default Value |
Server_Url |
http://localhost/ServicesAPI |
The URL used to call the Web API service, http://<IP address of NetBrain Web API Server>/ServicesAPI. For example, http://10.10.3.141/ServicesAPI. Note: If SSL will be enabled with https binding created for the system website in IIS Manager, type https in the URL. Besides, if CA_Verify is enabled, hostname must be specified in the URL. |
Server_Key |
Admin1.# |
The key used to authenticate the connections to your NetBrain Web API Server. Note: The Server_Key must be kept consistent with the key configured when you installed Web API Server. |
LogPath |
/var/log/netbrain/nbagent |
The storage path for the log files of the Service Monitor Agent. Note: At least 10GB free disk space is required. |
CA_Verify |
no |
Set whether to authenticate the Certificate Authority (CA) of the certificates, which are used to enable SSL for the system website in IIS Manager. Note: It is required only if https is used in Server_Url. |
CertAuth |
/etc/ssl/cacert.pem |
The storage path and file name of the root or class 2 CA file used for CA authentication. Note: It is required only if CA_Verify is enabled. Only the CA file in the Base-64 encoded X.509 (.CER) format is supported. |
