The system provides the following types of parsers to parse data from different sources:
CLI Command Parser — define how to parse and extract key metrics from the outputs of a CLI command.
Configuration Parserdefine how to parse and extract key metrics from configuration files.
SNMP Parserdefine how to parse and extract key metrics from the outputs of an SNMP command.
API Parserdefine how to parse and extract key metrics from an SDN network or third-party system via rest APIs.
You can Selecting a Parsing Method.
