If the Execution tree is associated with an incident generated by API triggered runbook (via API stub or Event Template), the execution result of the respective Runbook Template will be displayed under the Automation Triggered by Third Parties category.
In the summary view, you can click View Result to open the respective Runbook and check the execution result of each Runbook Node.
