The Feature Intent Template can be tested via Validate YAML and Test Device Config Match.
The Validate YAML can be used to validate the syntax of the template.
•For a newly created Feature Intent Template:
The YAML validation is automatically executed after you click Save.
•For an existing Feature Intent Template:
Select the desired Feature Intent Template, click Validate YAML.
The purpose of Test Device Config Match Function is to test and sort out the matching configlets in the config file of the current device.
1.Select the desired Feature Intent Template, click Test Device Config Match.
2.In the Select Device window, select the device and click OK.
