You can set the parameters of the following nodes of a runbook when defining an event template:
▪Ping
Function |
Parameter |
qapp_node.set_current_baseline() |
N/A |
Run a Qapp once with the Current Baseline. |
qapp_node.set_pull_live_data_once() |
N/A |
Run a Qapp once with live data. |
qapp_node.set_pull_live_data_regularly(duration,unit,is_repeat,times) |
▪duration (int) — the time interview to run a Qapp. The valid value ranges from 1 to 60. ▪unit (int) — the time unit. The valid value is 1, 2 or 3. o1 Hour o2 Minute o3 Second ▪is_repeat (bool) — whether to run a Qapp constantly. ▪times (int) — the times to run a Qapp. The valid value ranges from 1 to 1000. |
Run a Qapp regularly with live data. |
qapp_node.set_share_alert_users(["userId", "userName"] |
▪userId (string) — the ID of an user in the system. If an user ID is not available, you can specify the username only in this function. ▪userName(string) — the username. |
Set the users that you want to share alerts with. ["userId":"49cf3c00-2eb2-42d4-ba7e-27d4d62508e7","userName":"admin"] |
qapp_node.set_email_settings([to],[level]) |
▪to (array) — the email accounts that the system sends alerts to. ▪level (array) — specify at which level the system send alert emails. o1 Error o2 Warning |
Set email receivers and the level to send an alert. qapp_node.set_threshold("[email protected]","1") |
qapp_node.set_threshold() |
•name (string) — the name of the variable you want to set threshold. •Value (string) — the threshold value. |
Set the threshold. |
qapp_node.set_variable_input() |
name (string) — the name of the input variable object. |
Set variable input. qapp_node.set_variable_input("Group","1") |
Function |
Parameter |
gapp_node.set_current_baseline() |
N/A |
Run a Gapp once with the Current Baseline. |
gapp_node.set_pull_live_data_once() |
N/A |
Run a Gapp once with live data. |
gapp_node.set_pull_live_data_regularly(duration,unit,is_repeat,times) |
▪duration (int) — the time interview to run a Gapp. The valid value ranges from 1 to 60. ▪unit (int) — the time unit. The valid value is 1, 2 or 3. o1 Hour o2 Minute o3 Second ▪is_repeat (bool) — whether to run a Gapp constantly. ▪times (int) — the times to run a Gapp. The valid value ranges from 1 to 1000. |
Run a Gapp regularly with live data. |
gapp_node.set_share_alert_users(["userId", "userName"] |
▪userId (string) — the ID of a user in the system. If an user ID is not available, you can specify the username only in this function. ▪userName(string) — the username. |
gapp_node.set_email_settings([to],[level]) |
▪to (array) — a list email accounts that the system sends alerts to. ▪level (array) — specify at which levels the system send alert emails. o1 Error o2 Warning |
Set email receivers and the level to send an alert. gapp_node.set_email_settings([[email protected]],[2,1]) |
gapp_node.set_threshold() |
Set the threshold. gapp_node.set_threshold("Shared Qapps in Tenant/FlowCase_API/API_down2","bandwidth","0") |
gapp_node.set_variable_input() |
Set variable input. gapp_node.set_variable_input("Group","1") |
Function |
Parameter |
ping_node.set_from_by_auto_font_server |
N/A |
Automatically select a front server as ping source. |
ping_node.set_from_by_device("device_name", "interface") |
▪device (string) — the device name. ▪interface (string) — the interface name. |
Set the source of a ping. |
ping_node.set_to_by_device("device_name", "interface") |
Set the destination of a ping. |
ping_node.set_to_by_ip_address("ip_address") |
▪ip_address (string) — the IP address. |
Set a specific IP address as the destination of a ping. |
ping_node.set_option(timeout, package_size, package_count, no_fragment_flag) |
▪timeout (int) — the maximum time of ping packets to wait for a response. ▪package_size (int) — the size of ping packets to be processed before the results and averages are calculated. ▪package_count (int) — the number of ping packets to be processed before the results and averages are calculated. ▪no_fragment_flag (bool) — specify whether to include the fragment flag when sending packets. |
Define the advanced settings of a ping. |
Function |
Parameter |
trace_node.set_from_by_auto_font_server |
N/A |
trace_node.set_from_by_device("device_name", "interface") |
Set the source of a traceroute. |
trace_node.set_to_by_device("device_name", "interface") |
Set the destination of a traceroute. |
trace_node.set_to_by_ip_address("ip_address") |
Set a specific IP address as the destination of a traceroute. |
trace_node.set_option(timeout, max_hops) |
▪timeout (int) — the maximum time to wait for a response. ▪max_hops (int) — the maximum number of hops to reach the destination device. |
Define the advanced settings of a traceroute. |
Function |
Parameter |
cli_command_node.set_cli_commands([ ]) |
▪command (array) — a list of CLI commands |
Define the CLI commands to retrieve data. cli_command_node.set_cli_commands(['show version','show interface']) |
Function |
Parameter |
retrieve_node.set_retrieve_commands([ ]) |
Define the CLI commands to retrieve data. retrieve_node.set_retrieve_commands(['show version','show interface']) |
retrieve_node.set_retrieve_datas() |
▪config (bool) — whether to retrieve device configurations. ▪route_table (bool) — whether to retrieve route tables. ▪ARP_table (bool) — whether to retrieve ARP tables. ▪MAC_table (bool) — whether to retrieve MAC tables. ▪NDP_table (bool) — whether to retrieve NDP tables. ▪STP_table (bool) — whether to retrieve STP tables. ▪device_info (bool) — whether to retrieve device information. ▪intf_info (bool) — whether to retrieve interface information. ▪BGP_table (bool) — whether to retrieve BGP tables. |
Set the data to retrieve. config=True, route_table=True, ARP_table=True, MAC_table=True, NDP_table=True, STP_table=True, device_info=True, intf_info=True, BGP_table=True) |
retrieve_node.set_retrieve_nct_table([]) |
▪nct_table (array) — NCT tables to retrieve. |
Set the NCT tables to retrieve. retrieve_node.set_retrieve_nct_table(['Contract Table','EPG Contract Table']) |
retrieve_node.set_update_to_baseline() |
▪True — update the retrieved data to the current baseline. ▪False — do not update the retrieved data to the current baseline. |
Define whether to update the retrieved data to the current baseline. retrieve_node.set_update_to_baseline(False) |
Function |
Parameter |
aam_node.set_current_baseline() |
N/A |
Run the node with the Current Baseline. |
aam_node.set_live_network() |
N/A |
Run the node with the live data. |
aam_node.set_live_use_baseline_config() |
▪True — use the configurations in the current baseline when running the node with the live data. ▪False — do not use the configurations in the current baseline when running the node with the live data. |
Define whether to use the configuration data in the current baseline when running the node with the live data. aam_node.set_live_use_baseline_config(False) |
aam_node.set_option |
▪calc_l3_active_path (bool) — whether to calculate the Layer 3 path by using live data ▪calc_when_denied_by_acl (bool)— Whether to enable ACL checK before calculating a path. If enabled, the system ignores the ACL check at a path calculation. ▪calc_when_denied_by_policy (bool) — Whether to enable policy check before calculating a path. If enabled, the system ignores the policy check at a path calculation. ▪enable_path_fixup (bool) — Whether to enable path gateway fix-up during a path calculation |
Define the settings of path calculation. aam_node.set_option(calc_l3_active_path=False, use_commands_with_args=False, calc_when_denied_by_acl=False, calc_when_denied_by_policy=False, enable_path_fixup=True) |
aam_node.set_share_alert_users([]) |
Set the users that you want to share alerts with. aam_node.set_share_alert_users(["userId":"49cf3c00-2eb2-42d4-ba7e-27d4d62508e7","userName":"admin"]) |
aam_node.set_email_settings([], []) |
Set email receivers and the level to send an alert. aam_node.set_email_settings([[email protected]],[2,1]) |
Function |
Parameter |
dvt_node.set_current_baseline() |
N/A |
Run a data view template once with the Current Baseline. |
dvt_node.set_pull_live_data_once() |
N/A |
Run a data view template once with live data. |
dvt_node.set_pull_live_data_regularly(duration, unit, is_repeat=, times) |
▪duration (int) — the interval to run a Qapp. the valid value ranges from 1 to 60. ▪unit (int) — the time unit. The valid value is 1, 2 or 3. o1 Hour o2 Minute o3 Second ▪is_repeat (bool) — whether to run a Qapp constantly. ▪times (int) — the times to run a Qapp. The valid value ranges from 1 to 1000. |
Run a data view template regularly with live data. dvt_node.set_pull_live_data_regularly(duration=4, unit=2, is_repeat=True, times=10) |
dvt_node.set_template_variables([]) |
▪variable (string) — the variable name. ▪value (string) — the variable value. |
Define the values for data view template variables. dvt_node.set_template_variables([{"alias":"manual_input_tem","value":1}]) |
dvt_node.set_device_variables() |
▪deviceName (string) — the device name. ▪alias (string) — the alias name of a variable. ▪value (string) — the value of a variable. |
Define the values for device-level variables. [{ |
