You can retrieve the following data types for each device from the Device Details pane:
Take configuration file for example:
1.In the Device Details pane, select the Configuration File tab.
2.Click the
 icon to open the configuration file in a pop-up dialog.
3.Click the
 icon to retrieve the configuration file from the live network. See Default Live for more details.
Tip: To batch retrieve live data for various data types, click Retrieve Live Data from the right-click menu of a map. See Retrieving Live Data for more details.
▪Opening the Device Details Pane
