Parser Library is a self-contained manager that provides you with a comprehensive view of all accessible parser files.
▪Built-in Parsers — contains the pre-installed parser files. This category is accessible to all users but can only be modified by system administrators.
▪Shared Parsers in Tenant — contains parser files that are accessible to all users in this tenant.
▪My Parsers — contains parser files that are only accessible to yourself. You can find your private parsers in all accessible domains under one tenant.
1.Click the start menu
and select Parser Library.
2.Point to a parser file and click the
icon to preview it.
