Functions related to Guidebook Modification:
•Remove Runbook Template and Network Intent
•Modify Guidebook in Decision Tree
1. In Create Guidebook interface, mouse over a Hypothesis.
2.Click , then you can inline modify the Hypothesis.
1.In Create Guidebook interface, mouse over a Hypothesis and click .
2.Click Remove in the Warning window.
Note:The Hypothesis and its associated Runbook Template/Network Intent will be deleted from this Guidebook.
1.In Create Guidebook interface, mouse over the note and click .
The Runbook Template and Network Intent associated with Hypothesis can be removed from a Guidebook.
1.In Create Guidebook interface, mouse over a Runbook Template/Network Intent, and click .
2.Click Remove in the Warning pop-up window. The Runbook Template or Network Intent will be removed from this Guidebook.
1.In Create Guidebook interface, mouse over the Data View Template, and click .
Note: The Data View Template and its respective Runbook Template/Network Intent will be deleted from this Guidebook.
1.In Decision Tree interface, click the current Guidebook.
2.In the select Guidebook drop-down list, hover over the intended Guidebook and click .
