Additional functions related to execution tree management are listed as below:
You can edit the relationship by changing its notes, trigger rules.
1.Hove over the interested relationship, and click .
2.Select Edit Relationship from the drop-down list.
3. Edit note or Trigger rule in the Triggered Automation Details window.
You can Uninstall Intent to remove the network intent from the current probes.
2.Select Uninstall Intent from the drop-down list.
3.Click Save in the Uninstall Intent window.
