Appendix: Functions for Compound Variables
In addition to the available variable types introduced in chapter 2.1, the system provides built-in functions for you to define compound variables to convert predefined variables in terms of variable types, units, values, etc.
Note: A compound variable must be a single-value variable of the string, integer, or double type.
The following table introduces the built-in functions that will assist you in defining compound variables.
Function Name
Description
Data Type of Input Parameter
Sample of Input Parameter
Data Type of Return
Sample of Return
IPStringToNumber
Convert an IP address from string format to an integer. Masked IP address is allowed, e.g., “192.168.91.1/28”.
Note: Returning “-1” represents error.
String
IPStringToNumber(“192.168.91.1”)
Int (long)
3232258817
NumberToIPString
Convert an IP address from integer format to string format.
Note: Returning NULL (“”) represents error.
Int (long)
NumberToIPString(3232258817)
String
“192.168.91.1”
PercentageToNumber
Remove the percentage sign (%).
String
PercentageToNumber(“50%”)
Int
Double
50
ByteConverter
Convert storage units (such as KB, MB, GB, etc.) to byte.
Note: The input parameter is case-insensitive, and abbreviations are allowed, e.g., GB, G, g.
String
ByteConverter(“35MB”)
Int
Double
36,700,160 Bytes
(35x1024x1024)
NumberToString
Convert a number to string format.
Int
Double
NumberToString(5)
String
"5"
StringToNumber
Convert a string-type number to int or double format.
String
NumberToString(“19”)
Int
Double
19
IPtoHostname
Obtain a device hostname by using a given IP address. Masked IP address is allowed, e.g., “192.168.91.1/24”.
Note: If an IP address is being used by multiple devices, the hostname of a random device among those matches will be returned.
String
IPtoHostname(“192.168.91.1”)
String
“R1”
TrimRight
Trim one or more characters on the right side of a given string. If the designated character is left blank, it will be identified as a space character.
Format: TrimRight($var, ”char”)
String (original string),
String (char)
TrimRight(“4.03,” ”,”)
String
“4.03”
TrimLeft
Trim one or more characters on the left side of a given string. If the designated character is left blank, it will be identified as a space character.
Format: TrimLeft($var, “char”)
String (char)
TrimLeft(”-4.03”, ”-“)
String
“4.03”
Replace
Replace one character with another in a given string.
Format: Replace($var, “char_old”, “char_new”)
String (old char),
String (new char)
Replace(”2020-8-23”, “-”, “/“)
String
“2020/8/23”
FormatMAC
Format MAC addresses using NetBrain-specific standard (period-separated hexadecimal notation).
String
FormatMAC(“D8-67-D9-86-59-40”)
String
“d867.d986.5940”
