Flash Probe
Network Intent
Triggered Automation
Data View Template
Golden Baseline
Schedule CLI Tasks
Scheduled Task
Runbook Template
Guidebook
Flash Probe
Action
YAML Sample
Properties
Action
Create
omultiple flash probes for device
osupport compound variable
osupport reference variable of the feature as parser parameter
osupport reference GB dynamic rule
Trigger
otrigger flash probe of the same device
YAML Sample
flash_probes: # Definition for generating Flash Probe.
 - name: BGP_Flapping#{ $ip1 }
   display_name: BGP_Flapping#{ $ip1 } # display name, optional
   description: xxxx
   target_type: Interface # Device or Interface
   target_interface: $intfName # target interface name, valid for target_type=Interface, null means all interfaces
   qulification: | # qulification to filter the Device/Interface
     $device.subTypeName=="Cisco Router" && $intf.name!="e0" && $intf.xxx=="xx"
   conflict_mode: Skip # support values: Override and Skip, the default value is Skip
   type: Primary # Primary or Secondary or External
   trigger_type: AlertBased # AlertBased or TimerBased, AlertBased is the default value, valid for type=Primary
   alert_source: ServiceNow # valid for type=External, such as ServiceNow...
   frequency_multiple: 16 # multiple of the period of the base frequency valid for target_type=Device&&type=Primary&&trigger_type=TimerBased
   variable_defines: # the variables that may be used in rule or alert_message, valid for type=Primary|Secondary&&trigger_type=AlertBased
     - parser: "Built-in Files/CLI Command/Cisco IOS/Ping [Cisco IOS]"
       parameters:
         vrf: $xx
         ip: $ip1
       variables: # the variables that want to use in rule or alert_message
         - name: status # variable full name
           alias: status # alias that is actually used when referenced in Rule and alert_Message, same as 'name' if alias have no value
           monitor: # It indicates this variable needs to be monitored
             display_name: xxx_status # display name which show up on the map data view.
             unit: xxx_status # unit which show up on the map data view.
     - parser: "Built-in Files/CLI Command/Cisco IOS/Interface xxx"
       variables:
         - name: intf.status
           alias: intfStatus
     - compound_variable: xxx1
       expression: $status
     - compound_variable: xxx2
       expression: $status+3
   rule: # valid for type=Primary|Secondary&&trigger_type=AlertBased
     loop_table_rows: false
     conditions:
       - operand1: $status
         operator: NotEqual # 1. UseGB, 2...
         operand2: "Success"
       - operand1: $status
         operator: NotEqual
         operand2: $status[last]
     boolean_expression: A or B
   alert_message: have bgp flapping alert $status # alert meessage, support variables, valid for type=Primary|Secondary&&trigger_type=AlertBased
   triggered_by: # flash probe list that triggered by, valid for type=Secondary&&trigger_type=AlertBased
     - name: FlashProbe1 # flash probe name, device level, same device&interface
       target_type: Device # Device or SameLevel, SameLevel is the default value
   enable: true # whether to enable
   send_email: # send email when alert occurs.
     enable: true
     emails:
       - [email protected]
       - [email protected]; [email protected]
     trigger_event_template: New Template # optional, name of event template that will trigger when send email
   enable: true # whether to enable, the default is true
Properties
Property Name
Type
Required
Definition
name
string
Y
Flash name
display_name
string
N
It shows in IE Probe Flash UI. The default is the same with the name parameter.
description
string
N
The flash probe description
target_type
enum
N
There are 2 target types:
Device(default)
Interface
target_interface
string
N
If the target type is Interface, this parameter is available. It also references the feature variable as the value, such as $IntfName.
qualification
string
N
The qualification of the flash probe. It can use the GDR variable or feature variable as a condition, such as :$device.subTypeName=="Cisco Router" && $intf.name!="e0" && $intf.xxx=="xx"
It supports device GDR attribute and physical interface GDR attribute.
See Qualification Properties and Condition
conflict_mode
string
N
Override or Skip(default)
type
string
N
Primary(default), Secondary and External are supported.
trigger_type
string
N
This parameter is valid if the type parameter is Primary. It supports AlertBased (default)and TimerBased.
alert_source
string
N
This parameter is valid if the type parameter is External, such as 'ServiceNow'.
frequency_multiple
int
Y
Multiple of the period of the base frequency.
It is valid for target_type=Device&&type=Primary&&trigger_type=TimerBased
variables_defines
object
N
It may be used in rule or alert_message. It is valid for type=Primary|Secondary&&trigger_type=AlertBased.
variables_defines.parser
list
N
Parser path
variable_defines.parameters.{var1}
string
N
The parser parameter variable,and {var1} is the variable name.
variable_defines.variables
object
N
The variables to be used in rule or alert_message
variable_defines.variables.name
string
N
The variable of the parser full name
variable_defines.variables.alias
string
N
The alias actually used when referenced in rule and alert_Message, same as 'name' if alias has no value.
variable_defines.varaibles.monitor
object
N
It indicates that this variable needs to be monitored.
variable_defines.varaibles.monitor.display_name
string
N
Display the name which shows up on the map data view.
variable_defines.varaibles.monitor.unit
string
N
As a variable unit and shows up on the map data view.
variable_defines.compound_variable
object
N
The compound variable name, and defining multiple compound variables is supported.
variable_defines.compound_variable.expression
string
N
Define the compound variable expression such as $var > 0 and $var2 !=None.
rule
object
N
Define rule for the flash probe . It is valid for type=Primary|Secondary&&trigger_type=AlertBased
rule.loop_table_rows
bool
N
The default is true.
It will be set as true if the variable is the table.
rule.conditions
object
N
The rule condition
rule.conditions.operand1
string
N
rule.conditions.operator
object
N
The rule condition operator expression, such as Equal, Not Equal.
It supports dynamic GB rule as well.
rule.conditions.operand2
string
N
rule.conditions.boolean_expression
string
N
The rule bool expression
alert_message
string
N
The alert message, which supports variable input such as $status.
triggered_by
object
N
The triggered flash probe list
It is valid for type=Secondary&&trigger_type=AlertBased.
triggered_by.name
string
N
The triggered flash probe name
triggered_by.target_type
string
N
Device#Device or SameLevel(default)
enable
bool
N
Whether to enable the flash probe being created or not
send_mail
object
N
Setting email content for flash probe.
send_mail.enable
bool
N
The default is true when there is the send_email tag and at least one valid email address is filled in.
emails
list
N
The email address list
string
N
The name of the event template to be triggered when sending an email .
Network Intent
Action
YAML Sample for Template
YAML Sample for Diagnoses
Properties
Action
Create
ocreate a NI by feature decode
ocreate a default NI if the "create_default_NI" tag is true
Trigger
oTriggered Automation
network_intents: # Definition for generating NI.
 ref_label: ospf
 path: All Network Intents/General_BGP_{$crossRelationHash} # the path to generate NI, here can use variables of FIG level
 conflict_mode: Skip # support values: Override and Skip, the default is Skip
 lock_after_created: true # the default is false
 create_default_NI: true # Whether to create Default NI for the FIG, the default is false.
 baseline_update_type: LatestFromDE # support values: LatestFromDE(Relative to the time of running FID), LiveFromNextRun, the default is LatestFromDE.
 ni_template: "./NI_template1.ni" # Relative path of the NI Template file, NI will be generated from the NITemplate when create_default_NI=false.
 ni_inputs:
   devices:
     R1:
       # repeat: false # Whether to generate the Device in NI for all Device of FIG replication that meets the criteria, the default is false.
       device_condition: order('$bgp')==1 # FIG Device to NI Device Mapping condition.
       # If repeat=true and there are multiple devices that meet this condition, the NI Device will be copied to generate.
       parameters:
         intf: $intfName1
         ip: $ip1
         # here can use variables and functions of device level
         # line pattern va riables and GDR variables are available here
         # line pattern variable write like this: $bgp, without a prefix.
         # GDR variable write like this, $device.subType, with prefix $device.
     R2:
       device_condition: order('$bgp')==2
       parameters:
         intf: $intfName1
         ip: $ip1
common_role_variables:
   - name: roleVarible1
     from_role: role1 # role which the variable come from
     device_condition: true # optional, take the first device in the role that meets the condition
     variable: "Conmand2.var3"
 analysis_devices:
   - device_role: role1
     device_condition: expression($fi.xxx)=="yyyy1"
     local_role_variables:
       - name: roleVarible2
         from_role: Role2 # role which the variable come from
         device_condition: $device.xxx == $ni.role2.current.device.xxx
     commands:
       - type: Command # Command or Config
         id: Conmand1 # samle: cmd1, config1
         command: show interface { $fi.intfName1 } # only for type=Command
         description: xxxxx
         parser: "./VisualParser.xpar"
         compound_variables:
           - name: var1 # Must be unique in the all compound variables in this NI
             value_type: string # string or number
             expression: $Config1.version+"_"+$ni.roleVarible1 + $ni.roleVarible2.GetLength() # only support the single variables from current device
         merged_tables: # table cannot be used across devices
           - name: vlan_table3
             table1:
               table: Command1.Paragraph1 # table cannot be used across devices
               paired_keys: [intf, key2] # suport multi key fields, the order of the fields must match with right join_keys
             table2:
               table: Command2.Table2
               paired_keys: [ip, key2]
             table_keys: [Command1.Paragraph1.intf, Command2.Table2.column2]
             # columns: # not supported in v10.0a and will be supported in the next version
             #   - name: intf11
             #     orig_col_name: Command1.Paragraph1.intf # the column full name from table1 or table2
             #     is_table_key: true
         diagnoses:
           - anchor: Paragraph1.intf_name # optional, only support the variables from current config/command
             note: xxxxxxxx # donot support variable
           - anchor: Paragraph1.ip
             description: check the ip accuracy
             if:
               rule:
                 loop_table_rows: true # the default is false
                 conditions:
                   - operand1: Command1.Paragraph1.ip[Current] # [] support values: Current,Last,Baseline, the default is Current
                     operator: Does Not Equal #  Equals, Contains....
                     operand2_type: ConstFromFITExp # support types: Auto, Const, Var, ConstFromFITExp, the default is Auto, Auto will be automatically recognized
                     operand2: "abc"+$fi.var1 # support to use FI or GDR variables if operand2_type=ConstFromFITExp
                   - operand1: Command1.Paragraph2.mask
                     operand2: ni.roleVarible1[Current]
                 boolean_expression: not (A or B)
               then:
                 note:
                   color: red # supports red, green and other color values, the default is red
                   text: Diagnosis Alert $Command1.Paragraph2.mask,$ni.roleVarible1
                 status_code_for_this_device:
                   enable: true # the default is false
                   type: Alert # Success or Alert, the default is Alert
                 status_code_for_ni:
                   note: Diagnosis Alert $Paragraph1.ip
               else: # optional
                 note:
                   color: green # supports red, green and other color values, the default is green
                   text: Diagnosis Success
                   enable: true
                   type: Success # Success or Alert, the default is Success
                 status_code_for_ni:
                   enable: true
                   note: Diagnosis Success
   - device_role: role2
Properties
Property Name
Type
Required
Definition
path
string
Y
The path to generate the Network Intent.
Only use the crossRelationHash variable here.
ref_label
string
N
Define a label that can be referenced by other assets.
conflict_mode
string
N
Skip(default) or Override
Verify if the asset being created have already existed.
create_default_NI
bool
N
Whether to create the Default Network Intent for the FIG.
The default value is false.
The parameter is valid if the the Network Intent template does not exist or None
lock_after_created
bool
N
Lock the created Network Intent.
string
N
LatestFromDE(compared to the time of running FIT) or LiveFromNextRun,
The default value is LatestFromDE.
ni_template
string
N
The relative path of the Network Intent Template file.
ni_inputs
object
N
Devices included in the Network Intent.
ni_inputs.devices.R1
string
N
Satisfy R1 condition.
ni_inputs.devices.R1.device_condition
string
N
ni_inputs.devices.R1.parameter
string
N
object
N
Define one or more common variable(s).
common_role_variables.name
string
N
A Common role variable name
common_role_variables.from_role
string
N
The role name from which the variable comes
common_role_variables.device_condition
string
N
The common role variable condition
common_role_variables.variable
string
N
The variable from which the command comes
analysis_devices
obejct
Y
analysis_devices.device_role
string
Y
Define the device role name.
analysis_devices.device_condition
string
Y
Define the condition for device analysis.
analysis_devices.local_role_variables
object
N
analysis_devices.local_role_variables.name
string
N
The local variable name
analysis_devices.local_role_variables.from_role
string
N
The role name from which the local common variable comes
analysis_devices.local_role_variables.variable
string
N
analysis_devices.local_role_variables.device_condition
string
N
analysis_devices.commands
object
N
analysis_devices.commands.type
string
Y
There are two types:
Command
Config
analysis_devices.commands.id
string
Y
The command id.
Including it as a prefix to invoke the current command variable, such as command1.cpu
analysis_devices.commands.description
string
N
analysis_devices.commands.parser
string
N
Reference the path of the parser.
analysis_devices.commands.compound_variables
object
N
Define the compound variable for this NI.
analysis_devices.commands.compound_variables.name
string
N
analysis_devices.commands.compound_variables.value_type
string
N
Two types:
String
Number
analysis_devices.commands.compound_variables.expression
string
N
analysis_devices.commands.merged_tables
object
N
Define the merged table for this NI.
analysis_devices.commands.merged_tables.name
string
N
analysis_devices.commands.merged_tables.table1
object
N
analysis_devices.commands.merged_tables.table1.table
string
N
analysis_devices.commands.merged_tables.table1.paired_keys
list
N
analysis_devices.commands.merged_tables.table2
object
N
analysis_devices.commands.merged_tables.table2.table
string
N
analysis_devices.commands.merged_tables.table2.paired_keys
list
N
analysis_devices.commands.merged_tables.table2.table_keys
list
N
analysis_devices.commands.diagnoses
object
Y
Define the diagnoses for this NI
analysis_devices.commands.diagnoses.anchor
string
Y
Define the anchor for this diagnoses.
The anchor is optional.
analysis_devices.commands.diagnoses.note
string
Y
Must define either note or name.
analysis_devices.commands.diagnoses.name
string
Y
analysis_devices.commands.diagnoses.description
string
N
analysis_devices.commands.diagnoses.if
string
Y
The definition of the diagnoses starts here.
analysis_devices.commands.diagnoses.if.rule
string
Y
analysis_devices.commands.diagnoses.if.rule.loop_table_rows
string
N
The default is false.
analysis_devices.commands.diagnoses.if.rule.conditions
string
Y
analysis_devices.commands.diagnoses.if.rule.conditions.operand1
string
Y
analysis_devices.commands.diagnoses.if.rule.conditions.operator
string
Y
analysis_devices.commands.diagnoses.if.rule.conditions.operand2_type
N
The supported types:
Auto(default, and will be automatically recognized)
Const
Var
ConstFromFITExp
string
N
analysis_devices.commands.diagnoses.if.rule.boolean_expression
string
Y
analysis_devices.commands.diagnoses.if.then
object
Y
analysis_devices.commands.diagnoses.if.then.note
string
Y
analysis_devices.commands.diagnoses.if.then.note.color
string
Y
Colors supported:
red,green or other colors(using RGB value)
analysis_devices.commands.diagnoses.if.then.note.text
string
Y
analysis_devices.commands.diagnoses.if.then.status_code_for_this_device
object
N
analysis_devices.commands.diagnoses.if.then.status_code_for_this_device.enable
bool
N
true
false(default)
analysis_devices.commands.diagnoses.if.then.status_code_for_this_device.type
enum
N
Alert(default) or Success
analysis_devices.commands.diagnoses.if.then.status_code_for_ni.enable
bool
N
true
false(default)
analysis_devices.commands.diagnoses.if.then.status_code_for_ni.type
enum
N
analysis_devices.commands.diagnoses.if.then.status_code_for_ni.note
string
N
analysis_devices.commands.diagnoses.if.else
object
N
analysis_devices.commands.diagnoses.if.else.note
string
N
analysis_devices.commands.diagnoses.if.else.note.color
string
N
Colors supported:
analysis_devices.commands.diagnoses.if.else.note.text
string
N
analysis_devices.commands.diagnoses.if.else.status_code_for_this_device
object
N
analysis_devices.commands.diagnoses.if.else.status_code_for_this_device.enable
bool
true
false
analysis_devices.commands.diagnoses.if.else.status_code_for_this_device.type
enum
N
Alert or Success(default)
analysis_devices.commands.diagnoses.if.else.status_code_for_ni.enable
bool
N
true
false
analysis_devices.commands.diagnoses.if.else.status_code_for_ni.type
enum
N
Action
YAML Sample
Properties
Action
Install Triggered Automation
oCreate trigger automation asset:
The Network Intent
The Flash Probe
YAML Sample
triggered_automations:
 - description: xxxx
   automations:
     network_intents:
       - Public NIs/BGP/General HSRP
     auto_append_created_ni: true # Whether to automatically add the created NI by this FIT
     auto_append_created_ni_with_ref_labels: [ospf, xxxxx]
     external_assets:
       - from_fit: fit1/FIT_Root # The FIT to which the asset to be referenced belongs.
         auto_append_created_ni: false # Whether to add all the created NI by specified FIT, the default is false
         auto_append_created_ni_with_ref_labels: [ospf] # ref the NIs with the ref_labels from the specified FIT.
   triggered_by_flash_probes: # flash probe list that triggered by
       qualification: | # qulification to filter the Device/Interface
       note: Check bgp # note on decision tree
       playbooks: [BGP, HSRP] # note on decision tree
       trigger_rule:
         run_type: Once # Once or Continuously
         frequency: # run frequency for Continuously
           interval: 20
           times: 3
         suppression:
           enable: true
           wont_run_twice_within: 15
Properties
Property Name
Type
Required
Definition
description
string
N
The triggered automation description
automation
object
Y
Include the NI definition.
Supports to reference current YAML created NI.
automation.network_intents
list
Y
References the NI path.
Supports multiple NIs.
automations.auto_append_created_ni
bool
N
Whether to automatically add the NI created by this FIT.
automations.auto_append_created_ni_with_ref_labels
list
N
Add the NI with the same labels
automations.external_assets
object
N
Add external assets
automations.external_assets.from_fit
string
N
The external FIT path
automations.external_assets.auto_append_created_ni
true
N
automations.external_assets.auto_append_created_ni_with_ref_labels
list
N
list object
Y
The triggered Flash Probe list.
triggered_by_flash_probes.name
string
Y
The Flash probe name
triggered_by_flash_probes.qualification
string
N
The qualification can use the GDR variable or feature variable as a condition, such as :$device.subTypeName=="Cisco Router" && $intf.name!="e0" && $intf.xxx=="xx"
triggered_by_flash_probes.note_on_decision_tree
string
N
A note displayed on decision tree
triggered_by_flash_probes.trigger_rule
object
Y
The Trigger rule definition
triggered_by_flash_probes.trigger_rule.run_type
string
Y
triggered_by_flash_probes.trigger_rule.frequency
object
Y
The run frequency for Continuously
triggered_by_flash_probes.trigger_rule.frequency.interval
int
Y
The unit is minute.
triggered_by_flash_probes.trigger_rule.frequency.times
int
Y
The repeated run times.
triggered_by_flash_probes.trigger_rule.suppression
object
N
The unit is minute.
triggered_by_flash_probes.trigger_rule.suppression.enable
bool
N
triggered_by_flash_probes.trigger_rule.suppression.wont_run_twice_within
string
N
conflict_mode
string
N
To verify if the triggered automation has a conflict.
Override or Skip (default)
enable
bool
N
Boolean value:
true (default) or false
send_mail
object
N
Setting email content.
send_mail.enable
bool
N
emails
list
N
string
N
The name of the event template to be triggered when an email is sent.
Data View Template
Action
YAML Sample
Properties
Action
Create
oCreate a Data View Template.
Schedule
oScheduled a Data View Template.
Install Recommended Automation
oRecommend Automation of installing Data View Template.
YAML Sample
dataview_templates: # DVTs that need to create
 - path: ">>Data View Templates>Public Data View Templates>xxxx_{$fi.eigen1}"
   create_for_level: FIG # FIG or Global, the default is Global
   ref_label: "refLabel1"
   tags: [BGP, HSRP]
   default_data_source:
     type: LiveRegularly # LiveOnce, LiveRegularly, CurrentBaseline, the default is CurrentBaseline
     frequency: # for LiveRegularly
       every: 2 # unit is minute
       repeat_times: 3 # repeat run times, if null means no repeat
   qualified_devices: # support all the GDR properties that ES supports
     dynamic_search:
       conditions:
         - property: subTypeName
           values: [Cisco IOS Switch]
         - property: name
           operator: Contains # support types: Contains, Match, NotCotrains, NotMatch
           values: "BJ"
         - property: _nb_feature
           values: "BJ"
       boolean_expression: A and B
     static_include:
       auto_append_matched_devices: false # the default is false
       devices: [R1, R2]
     static_exclude:
       devices: [R3, R4]
   recommended_automations: # dvt level recommended automations
     - auto_append_created_ni: true # Whether to automatically add the created NI by this FIT, the default is false
     - auto_append_created_ni_for_same_FIG: true # the default is true
     - auto_append_created_ni_with_ref_labels: [refLabel1, xxxxx]
     - auto_append_created_rbt: true # Whether to automatically add the created RBT by this FIT, the default is false
     - auto_append_created_rbt_with_ref_labels: [refLabel1]
     - auto_append_created_rbt_for_same_FIG: true
     - external_assets:
           auto_append_created_rbt: false # the default is false
           auto_append_created_rbt_with_ref_labels: [ospf]
     - name: Basic Commands
       type: CLI # support types: CLI, RunbookTemplate
       commands: # cli commands
         - "show verson"
         - "show standby {$fi.xxxx}"
       auto_append_feature_commands: true
       description: xxxx
     - name: Troubleshooting OSPF Neighbor State1
       type: RunbookTemplate # support types: CLI, RunbookTemplate
       path: "Built-in Runbook Templates/Sample Runbook/Troubleshooting/Troubleshooting OSPF Neighbor State" # runbook template path
       description: xxxx
     - name: NI1
       type: NetworkIntent # support types: CLI, RunbookTemplate
       path: "HSRP/General HSRP2" # runbook template path
       description: xxxx
   input_variables:
     - type: ParserParameter
       parser: "Built-in Files/CLI Command/Aruba WLC/IP Interface Brief [Aruba WLC]"
       parameters:
         - name: para1
           display_name: para1
           value: ($fi.eigen1+2)
           allow_manual_input: false # the default is false
         - name: para2
           value: $fi.eigen2
         - name: para3
           value: '"GDR:$vlan"'
   device_positions:
     - parser: "Built-in Files/CLI Command/HP ProCurve Switch/NTP Status [HP ProCurve Switch]"
       variable: sntp_mode
     - parser: "Built-in Files/CLI Command/Aruba WLC/IP Interface Brief [Aruba WLC]"
       variable: ip_intfs
       variable: ip_intfs1
       index: 5 # the dataview position index, if not set, the positions are set in array order by default.
     - type: Text # Text or ParserVariable, the default is ParserVariable
       title: "ospf: {$fi.var1}" # GDR property name, not display name
       content: xxxxxxxxxxxxxx{$fi.var1}xx
     - type: GDR # support types: GDR or Parser, the default is Parser
       variable: subTypeName # GDR property name, not display name
   interface_positions:
     - interface_type: IPv4 Interface
       positions:
           variable: ip_intfs.intf
Properties
Property Name
Type
Required
Definition
path
string
Y
The Data View Template full path
create_for_level
string
N
Global(default)
FIG
ref_label
string
N
tags
string
N
default_data_source
object
Y
default_data_source.type
string
Y
LiveOnce
LiveRegularly
CurrentBaseline(default)
default_data_source.frequency
string
N
It is valid if the type is LiveRegularly, and to set the frequency.
default_data_source.frequency.type
string
N
It is valid for LiveRegularly.
default_data_source.frequency.every
string
N
default_data_source.frequency.repeat_times
string
qualified_devices
object
Y
qualified_devices.dynamic_search
object
N
qualified_devices.dynamic_search.conditions
object
N
qualified_devices.dynamic_search.conditions.property
string
N
qualified_devices.dynamic_search.conditions.operator
string
N
qualified_devices.dynamic_search.conditions.value
string
N
qualified_devices.dynamic_search.boolean_expression
string
Y
qualified_devices.static_include
object
N
qualified_devices.static_include.auto_append_matched_devices
bool
N
Whether to automatically add the devices matched by Feature Decode
false(default) or true
qualified_devices.static_include.devices
list
N
Input a hostname.
qualified_devices.static_exclude
object
N
qualified_devices.static_exclude.auto_append_matched_devices
bool
N
Whether to automatically exclude the devices matched by Feature Decode
qualified_devices.static_exclude.devices
list
N
Input a hostname.
input_variables
object
N
input_variables.type
object
N
Only supports:
ParserParameter
input_variables.parser
string
Y
It is a must tag if defining input_variables object.
input_variables.parameters
object
Y
input_variables.parameters.name
string
Y
The parameter name.
Keep the name here the same as the one in parser command.
input_variables.parameters.display_name
string
N
input_variables.parameters.value
string
Y
input_variables.parameters.allow_manual_input
string
N
object
N
Currently only supports:
Execute CLI Commands.
Runbook Template.
Network Intent
recommended_automations.auto_append_created_ni
bool
N
recommended_automations.auto_append_created_ni_with_ref_labels
list
N
recommended_automations.auto_append_created_ni_for_same_fig
bool
N
recommended_automations.auto_append_created_rbt
bool
N
false(default)
true
recommended_automations.auto_append_created_rbt_with_ref_labels
list
N
recommended_automations.auto_append_created_rbt_for_same_fig
bool
N
recommended_automations.external_assets
object
N
recommended_automations.external_assets.from_fit
string
Y
recommended_automations.external_assets.auto_append_created_ni
bool
N
recommended_automations.external_assets.auto_append_created_ni_with_ref_labels
list
N
recommended_automations.external_assets.auto_append_created_rbt
bool
N
recommended_automations.external_assets.auto_append_created_rbt_with_ref_labels
list
N
recommended_automations.name
list-string
N
The Runbook template full path
recommended_automations.type
enum
N
CLI
RunbookTemplate
NetworkIntent
recommended_automations.commands
list
N
It is valid if the type is CLI.
recommended_automations.auto_append_feature_commands
bool
N
recommended_automations.description
string
N
recommended_automations.path
string
N
The Runbook Template or Network Intent path
device_positions
object
N
device_positions.parser
string
N
The parser path
device_positions.variable
string
N
The variable name
device_positions.index
enum
N
The data view position: 0, 1, 2 or 3, ...19.
device_positions.type
enum
N
GDR or Text
interface_positions
object
N
interface_positions.interface_type
enum
N
IPv4 Interface
Interface
IPv6 Interface
IPsec VPN Interface
GRE VPN Interface
interface_positions.positions
object
N
interface_positions.positions.parser
string
N
The parser path
interface_positions.positions.variable
string
N
The variable name
interface_positions.positions.index
enum
N
The data view position: 0, 1, 2 or 3, ...23.
Golden Baseline
Action
YAML Sample
Properties
Action
Create
oCreate Golden Baseline, Define a Golden Baseline Template. When running YAML, the matched device or interface will be automatically instanced. Note that all GB rules defined here are Auto and do not support Manual Rule in current version.
YAML Sample
golden_baselines:
 - parser: Built-in Files/Network Vendors/Cisco/Cisco IOS/show standby [Cisco IOS]
   variable: intfs.state
   enable_dynamic: true
 - parser: Built-in Files/Network Vendors/Cisco/Cisco Nexus/show hsrp [Cisco Nexus Switch]
   variable: intfs.priority
Properties
Property Name
Type
Required
Definition
parser
string
Y
The parser path
variable
string
Y
The variable name
enable_dynamic
bool
N
Boolean value:
true(default) or false
Schedule CLI Tasks
Action
YAML Sample
Properties
Action
Schedule
oScheduled CLI command in the backend.
YAML Sample
schedule_cli_tasks: # create Schedule CLI Task
 - command: show interface {$ip1}
   frequency_type: Low # Heigh or Medium or Low
   description: FID-General HSRP-Schedule CLI
   enable: true # whether to enable, true is default value
Properties
Property Name
Type
Required
Definition
command
string
Y
Show the  command.
frequency_type
enum
N
High, Medium or Low(default)
description
string
N
Describe the scheduled command.
enable
bool
N
Boolean value:
conflict_mode
enum
N
Scheduled Task
Action
YAML Sample
Properties
Action
Schedule
oScheduled  Parser or data view template task.
YAML Sample
schedule_tasks: # create Schedule Task
 - name: FID-General HSRP-Schedule Task
   auto_append_created_DVT: true # Whether to automatically add the created DVT by this FIT
   dataview_templates: # the DVTs that need to install by schdule task
     - ">>Data View Templates>Built-in Data View Templates>Cisco ACI>Fabric Health and Faults [Cisco ACI]"
     - ">>Data View Templates>Built-in Data View Templates>GeneralHSRP"
   parsers: # the parsers that need to install by schdule task
     - "Built-in Files/Configuration/Cisco IOS/EIGRP Configuration [Cisco IOS]"
   frequency:
     type: Daily # support values: Hourly, Daily and Weekly.
     time: 20:58:25
     day_of_week: Monday # support values: Monday, Tuesday, Wednesday, Thursday, Friday, Saturday and Sunday, valid when type=Weekly.
     timezone: Eastern Standard Time # see time zone: https://www.timeanddate.com/time/zones/
Properties
Property Name
Type
Required
Definition
name
string
Y
The schedule task name
bool
N
Boolean value:
true or false(default)
dataview_templates
list
N
The list of Data View Templates
parsers
list
N
The list of parsers
frequency
object
Y
Define the frequency.
frequency.type
enum
Y
It supports values: Hourly, Daily, and Weekly.
frequency.time
string
Y
An example: 20:58:25
frequency.day_of_week
enum
Y
It is valid when the type is Weekly.
It supports values: Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, and Sunday.
frequency.timezone
enum
Y
See time zone: https://docs.microsoft.com/en-us/windows-hardware/manufacture/desktop/default-time-zones
Runbook Template
Action
YAML Sample
Properties
Action
Create
oCreate a Runbook template.
oRecommend Automation of installing Runbook Template.
YAML Sample
runbook_templates:
 - path: "Shared Runbook Templates/{$fit.currentDomain}/xxx_{$fi.eigen1}"
   tags: [BGP, HSRP]
     dynamic_search:
       conditions:
         - property: name
           values: "BJ"
     static_include:
       devices: [R1, R2]
     static_exclude:
       devices: [R3, R4]
   nodes:
     - auto_append_created_dvt: true # Whether to automatically add the created RBT by this FIT, the default is false
     - auto_append_created_dvt_with_ref_labels: [refLabel1]
     - auto_append_created_dvt_for_same_FIG: true
     - external_assets:
           auto_append_created_dvt: false # Whether to add all the created DVT by specified FIT, the default is false
           auto_append_created_dvt_with_ref_labels: [ospf] # ref the DVTs with the ref_labels from the specified FIT.
     - type: DataviewTemplate # support types: DataviewTemplate, OverallHealthMonitoring, CLI, Qapp
       path: ">>Data View Templates>Built-in Data View Templates>_Built-in Data for LWAP"
       name: Data for LWAP
       description: xxxx  # optional
     - type: Qapp # support types: DataviewTemplate, CLI, Qapp, OverallHealthMonitor, OverallHealthView
       path: "Built-in Qapp/Qapp1"
       qualified_devices: # optional
         dynamic_search: ~
         static_include: ~
         static_exclude: ~
     - type: OverallHealthMonitor
       name: Overall Health Monitor
     - type: OverallHealthView
       name: Overall Health View
     - type: CLI
       auto_append_feature_commands: true # whether to automatically append the commands of feature to RunbookTemplate Nodes, only for the commands that not include line pattern variables
       commands:
         - command: show version # the format for a command with note
           note: note for command
         - show interface  # the format without note
         dynamic_search: # support all the GDR properties that ES supports
           conditions:
             - property: name
               values: "BJ"
         static_include:
           devices: [R1, R2]
         static_exclude:
           devices: [R3, R4]
Properties
Property Name
Type
Required
Definition
path
string
Y
The Runbook Template full path
create_for_level
enum
Y
Global(default)
FIG
ref_label
string
N
tags
list
N
qualified_devices
object
Y
object
N
object
N
string
N
string
N
string
N
string
Y
object
N
bool
N
Whether to automatically add the devices matched by Feature Decode:
false(default)
true
list
N
Input a hostname.
object
N
bool
N
false(default)
true
list
N
Input a hostname.
nodes
object
Y
Add runbook nodes. Currently supports:
DataviewTemplate
Qapp
OverallHealthView
CLI
nodes.auto_append_created_dvt
bool
N
false(default)
true
nodes.auto_append_created_dvt_with_ref_labels
list
N
nodes.auto_append_created_dvt_for_same_fig
bool
N
nodes.external_assets
object
N
nodes.external_assets.from_fit
string
Y
nodes.external_assets.auto_append_created_dvt
bool
N
false(default)
true
nodes.external_assets.auto_append_created_dvt_with_ref_labels
list
N
nodes.type
enum
Y
Currently supports:
DataviewTemplate
Qapp
OverallHealthView
CLI
nodes.path
string
N
nodes.name
string
N
nodes.description
string
N
nodes.commands
object
N
nodes.commands.command
list
N
nodes.commands.note
string
N
nodes.auto_append_feature_commands
bool
N
Whether to automatically append the commands of feature to RunbookTemplate Nodes; only for the commands not including line pattern variables.
true(default)
false
conflict_mode
enum
N
It supports value:
Guidebook
Action
YAML Sample
Properties
Action
Create
ogenerate DVT and its recommended assets relationship
ocreate hypothesis
YAML Sample
guidebooks:
 - name: guidebook1 under ({ $fig.GetDeviceNamesStr() })
   category: "nb3"
   description: xxxx
     dynamic_search:
       conditions:
         - property: name
           operator: Contains # support types: Matches, Does not match, Contains, Does not contain, Is/is
           values: "BJ"
     static_include:
       devices: [R1, R2]
       # qualification: $fi.xxx !="xxxxx"
     static_exclude:
       devices: [R3, R4]
       # qualification: $fi.xxx =="xxxxx1"
   automations:
     - type: DataviewTemplate # Support types: DataviewTemplate or Hypothesis
       auto_append_created_dvt: false # Whether to add all the created DVT by this FID, the default is false
       external_assets:
           auto_append_created_dvt: false # Whether to add all the created DVT by specified FID, the default is false
       dataview_templates:
     - type: Hypothesis
       auto_append_created_ni: false # Whether to add all the created NI by this FIT, the default is false
       auto_append_created_ni_with_ref_labels: [ospf, xxxxx] # refer NI by ref_label
       auto_append_created_ni_for_same_FIG: true # Whether to add the created NI for same FIG, only for create_for_level=FIG, the default is false
       auto_append_created_rbt: false # Whether to add all the created RBT by this FIT, the default is false
       auto_append_created_rbt_with_ref_labels: [ospf] # refer RBT by ref_label
       auto_append_created_rbt_for_same_FIG: true # the default is false
       external_assets:
       network_intents:
         - "HSRP/General HSRP1" # static NI
       runbook_templates:
         - "Built-in RBTs/BGP/General HSRP" # static RBT
Properties
Property Name
Type
Required
Definition
name
string
Y
The guidebook name
create_for_level
enum
Y
Global(default)
FIG
category
string
Y
The Guidebook category.
The requirement of the category:
a.Can have the maximum number of 8 characters.
b.Only letters and numbers are allowed.
c. The last character cannot be a number.
description
string
N
qualified_devices
object
Y
object
N
object
N
string
N
string
N
string
N
string
Y
object
N
bool
N
list
N
Input a hostname.
object
N
bool
N
list
N
Input a hostname.
automations
object
Y
automations.type
enum
Y
automations.auto_append_created_dvt
bool
N
It is a valid tag if the type is DataviewTemplate.
automations.auto_append_created_dvt_with_ref_labels
list
N
automations.auto_append_created_dvt_for_same_fig
bool
N
bool
N
It is a valid tag if the type is Hypothesis.
list
N
bool
N
bool
N
list
N
bool
N
object
N
string
Y
automations.external_assets.auto_append_created_dvt
bool
false(default)
true
automations.external_assets.auto_append_created_dvt_with_ref_labels
list
N
bool
N
false(default)
true
list
N
bool
N
false(default)
true
list
N
automations.dataview_templates
list
N
automations.network_intents
list
N
automations.runbook_templates
lsit
N
conflict_mode
bool
N
Supports values:
Override
Skip(default)
