FIT Expression and Function
Overview
Variable
Global Function
Expression
String Interpolation
Overview
In FIT YAML, there are several sections where variables can be defined and further used in expression and string interpolation.
GDR variables are also supported.
Variable
Naming Convention
Variables can be defined in line pattern and eigen variables.
Variable names are case-sensitive.
Variable names must begin with a letter of the alphabet or an underscore( _ ).
Variable names can contain letters and numbers.
No spaces or special characters are allowed.
The variable names should not have any duplicates.
Variable names should not be identical to the names of built-in functions or built-in keywords.
If the variable name being defined is not valid, the current decode process will be terminated.
Variable Level
Variable Definition Type
Variable Level
Definition
Line Pattern Variable
SubFI/Device Level
Defined in feature.configlet.match_rules.patterns .
Eigen Variable
SubFI/Device Level
Defined in feature.configlet.eigen_variables .
Device GDR Variable
Device Level
All device GDR variables.
Interface GDR Variable
Interface Level
All interface GDR variables. Physical interfaces only.
FIG Variable
FIG Level
A unique hash value for FIG groupby eigen variable
Variable Data Type
There are seven data types can be defined in line pattern or eigen variables. Besides that, device/interface GDR variables can also be utilized.
Device
String
Number
Bool
IP
IPv6
Mac
Time
Global Function
Function
Definition
Example
OrderIndex(string: deviceVarName, bool:asc=true): int
Get the order of current device in the feature intent group.
Can only be used in network_intents.ni_inputs.devices.[R1].device_condition.
OrderIndex("$priority")==0
OrderIndex("$device.priority")==0
Combine(paras any[] values): string
Combine multiple values into a sorted string.
Can only be used in feature.configlet.
Combine($ip1, $ip2, $bgp, $remoteBGP)
IP(string: ipString, string: maskString): ip
Create IPv4 object.
IP($ip,$mask)
IP($ipWithMask,"")
IPv6(string: ipString, string: maskString): ipv6
Create IPv6 object.
IPv6($ip,$mask)
IPv6$ipWithMask,"")
Ternary(bool: condition, any: value1WhenTrue, any: value2WhenFalse): any
Ternary.
SameSubnet(ip ip1, ip ip2): bool
Check whether the given ipv4 subnets are the same.
The mask length should be the same.
SameSubnet(ipv6 ip1, ipv6 ip2): bool
Check whether the given ipv6 subnets are the same.
Num(string: str1): number
Create a number object.
Num("90")
Str(any: obj)
Create a string object.
Str("SampleString")
Expression
The expression here is a statement written using a subset of C# language specifications.
There are several sections in FIT YAML that support the usage of string interpolation.
FIT YAML Tag
Type
Variables Level
Multiple Variable Values
feature.configlet.match_rules.relation
Feature Decode
Device level variables
Will generate commands for all possible values combinations.
feature.configlet.eigen_variables.expression
Feature Decode
feature.cross_relation.qualification
Feature Decode
NI
network_intents.ni_inputs.devices.[R1].parameters.[xx]
NI
Only the first value will be used if multiple values are available.
flash_probes.qualification
Flash Probe
Device / Interface level variables
flash_probes.generate_condition.variables.parameters.[xx]
Flash Probe
Introduction
https://docs.microsoft.com/en-us/dotnet/csharp/language-reference/tokens/interpolated
The expression is supported in "{ }".
To include a brace, "{" or "}", in the text produced by an interpolated string, use two braces, "{{" or "}}".
If string interpolation is not valid, current decode process will be terminated.
Examples
FIT YAML Tag
Type
Variables Level
Examples
feature.configlet.commands
Feature Decode
show standby interface {$intfName1} {$standbyName1}
network_intents.path
NI
FIG level variables
xxxx/xxxx/General_BGP_{ $crossRelationHash }
flash_probes.name
Flash Probe
BGP_Flapping_{ $intfName }
