This section introduces the hardware requirements, network connectivity requirements, and more prerequisites for deploying a distributed system.
▪Network Connectivity Requirements
Note: The following specifications only apply to traditional network. Refer to Public Cloud System Specification if you have activated the public cloud (AWS/Azure) license.
As the number of network devices and concurrent users increase, the system requires a distributed environment, which requires more machines to provide resiliency and scale out flexibly based on your network scale. Both physical machines and virtual machines are supported.
Select an appropriate deployment way according to your node count:
▪Distributed deployment for 2001-5000 nodes
▪Distributed deployment for 5001-10000 nodes
▪Distributed deployment for 10001-50000 nodes
Distributed deployment for 2001~5000 nodes
Environment |
NetBrain Component |
Machine Count |
CPU |
Memory 2) |
Hard Disk |
Operating System |
2001~5000 nodes |
Web Server |
1 |
4 Physical Cores 1) |
32GB |
200GB |
▪Windows Server 2012/2012 R2 (Standard/Datacenter Edition), 64-bit ▪Windows Server 2016/2019 (Standard/Datacenter Edition), 64-bit |
Worker Server |
1 |
8 Physical Cores 1) |
32GB |
200GB |
Front Server |
1 4) |
8GB |
▪200GB (HDD) ▪300GB (HDD) ▪300GB (SSD) |
▪Windows Server 2012/2012 R2 (Standard/Datacenter Edition), 64-bit ▪Windows Server 2016/2019 (Standard/Datacenter Edition), 64-bit ▪Red Hat Enterprise Linux Server 7.5/7.6/7.7/7.8/7.9/8.2/8.3/8.4, 64-bit ▪CentOS 7.5/7.6/7.7/7.8/7.9/8.2/8.3/8.4, 64-bit ▪Oracle Linux 7.7/7.8/7.9/8.2/8.3/8.4, 64-bit |
MongoDB |
1 |
32GB |
500GB (SSD) 4) |
Distributed deployment for 5001~10000 nodes
Environment |
Machine Count |
CPU |
Memory 2) |
Hard Disk |
Operating System |
5001~10000 nodes |
Web Server |
1 |
32GB |
200GB |
Worker Server |
2 |
32GB |
200GB |
Front Server |
2 |
8GB |
MongoDB |
1 |
64GB |
1TB (SSD) 4) |
Distributed deployment for 10001~50000 nodes
Environment |
Machine Count |
CPU |
Memory 2) |
Hard Disk |
Operating System |
10001~50000 nodes |
Web Server |
1 |
32GB |
200GB |
Worker Server |
3 |
32GB |
200GB |
Front Server |
3~10 |
8GB |
MongoDB |
1 |
128GB |
2TB (SSD) 4) |
Notes:
1) If hyper-threading is enabled, one physical core equals to two logical processors; in a virtual environment, the number of vCPUs required is twice the number of physical cores (as listed in the table).
2) Allocating at least half of the RAM amount for swap space on your Linux server is required to provide the necessary additional memory when the RAM space has been exhausted.
3) For good performance of data processing and caching, it is recommended to install the Front Server on a machine equipped with Solid State Drive (SSD) when managing up to 5000 nodes.
4) The required hard disk space must be exclusively reserved for NetBrain. And MongoDB must be installed on a machine equipped with Solid State Drive (SSD).
5) Minimum bandwidth requirement between Front Server Controller and each Front Server: 10Mbps.
6) If the Intent Based Automation (IBA) license is activated, It is recommended to install the Front Server on a machine equipped with:
- Solid State Drive (SSD) when managing up to 5000 nodes
- Hard Disk Drive (HDD) when managing up to 2000 nodes
7) In order to achieve the best performance, it is recommended that the network delay between the Front Server Controller and the Front Server be within 30ms.
Source |
Destination |
Protocol *) and Port Number **) |
Thin Client |
Web Server |
HTTP/HTTPS (80/443) |
Service Monitor Agent |
Web API Server |
Web API Server |
MongoDB |
TCP 27017 |
Web API Server |
Elasticsearch |
TCP (HTTP/HTTPS) 9200 |
Web API Server |
License Agent |
TCP 27654 |
Web API Server |
Redis |
TCP 6379 |
Web API Server |
RabbitMQ |
TCP 5672 |
Worker Server |
Front Server Controller |
TCP 9095 |
Front Server |
Live Network |
ICMP/SNMP/Telnet/SSH/REST API |
Front Server |
Ansible Agent (add-on) |
TCP 9098 |
MongoDB |
Web API Server |
TCP 9099 ***) |
Web API Server |
RabbitMQ |
TCP 15672 ***) |
Note: *) If SSL was enabled for any component including MongoDB/ElasticSearch/Redis/RabbitMQ/License Agent/Front Server Controller/Ansible Agent/Auto Update Server (within Web API Server), the SSL protocol should be added to firewall rules to enable SSL connection between servers.
Note: **) The port numbers listed in this column are defaults only. The actual port numbers used during installation might be different.
Note: ***) Ensure the newly added ports (9099 and 15672) are open for successful system upgrade to 10.0a.
▪The operating system must be installed with an English-language version (not language packs).
▪When installing NetBrain servers, comply with your company security policy to set the passwords and archive them for further reference.
▪NetBrain servers use hostnames to identify and communicate with each other. Make sure each server has a unique hostname.
▪Add all the NetBrain installation folders and files (on both Windows and Linux) to the allow list of antivirus software for routine scans, and keep the TCP connections unblocked between NetBrain components.
▪If the machine's firewall is turned on, make sure the firewall rules allow traffics to all the ports and protocols that will be used by the NetBrain system.
▪Special Requirements for Client Machine
oIt is recommended to deploy the NetBrain Smart CLI on the same machine where the browser-based thin client is used, and the machine needs to meet the following minimum system specifications: ❖4 Physical CPU Cores (If hyper-threading is enabled, one physical core equals to two logical processors; in a virtual environment, the number of vCPUs required is twice the number of physical cores) ❖8GB RAM oEnsure to reserve at least 50% system capacity for the satisfactory performance of NetBrain Browser-based Thin Client and Smart CLI Application. |
▪Special Requirements for Windows Server
▪Special Requirements for Linux Server
oUsers with root privileges of the machine are required to implement the installation. oIt is highly recommended to store the data files and log files of NetBrain servers into separated disk partitions. Make sure each partition has enough disk space. •More than 100GB free space in the directory where the data files of MongoDB/Elasticsearch will be saved. •More than 50GB free space in the directory where the log files of MongoDB/Elasticsearch will be saved. •More than 180GB free space for the Front Server PostgreSQL data path. |
