System Task Manager provides information about all back-end processes, including discovery/benchmark tasks, scheduled Qapps and so on. It automatically breaks a task into threads and enables you to end each process manually. Refer to System Task Status for more reference.
To terminate a task, complete the following steps:
2.In the System Management page, select Operations > Task Manager from the quick access toolbar.
3.Select the target task and click End Process.
The following table explains various status of a system task.
Status |
Running |
The task is being processed. |
Ready |
The task is ready to be processed. |
Pending |
The task is waiting in the task queue. |
Completed |
The task is completed. |
Error |
The task encounters an error during processing. |
