The browser-based interface of NetworkBrain Integrated Edition is backed by a full-stack architecture, adopting advanced distributed technologies to support large-scale networks with more expansion possibilities.
The distributed system architecture is as follows:
Note: The port numbers listed in the above architecture diagram are defaults only. The actual port numbers used during installation might be different.
The system components include:
Component |
provides a user interface for end users to access the system. |
serves as a system data repository. |
provides services that validate and activate licenses. |
serves as a full-text search and analytics engine in a distributed multi-user environment. |
Redis |
provides memory cache for the system. |
RabbitMQ |
prioritizes and forwards requested tasks. |
serves static content such as HTML, JavaScript, and CSS resources, which serves as the user interface of the Thin Client. |
Web API Server |
provides the front-end web applications to support the browser-based Thin Clients and serves RESTful API calls from third-party applications for integration. |
Worker Server |
serves as a resource manager to support computing tasks. It relies on both Redis and RabbitMQ to work. |
Task Engine |
coordinates computing tasks. |
Front Server Controller |
serves to coordinate and communicate with Front Servers and other components. |
serves as a polling server to collect and parse live network data. It is the only component required to access the live network. |
Service Monitor Agent |
monitors the health of your NetworkBrain Servers with operations management of related services. |
Ansible Agent (add-on) |
integrates with Ansible to define, execute playbooks and visualize results in Change Management Runbooks. See Ansible Integration for more details. |
Smart CLI (add-on) |
provides a Telnet/SSH client to connect to devices from Windows and can be integrated with NetworkBrain workflows. See Smart CLI for more details. |
The following table introduces the considerations for system scalability:
Server |
Scalability |
Web Server |
▪Multiple Web Servers can be installed as per data center locations and load-balanced under your load balancing infrastructure to ensure the response time for accessing web pages of Thin Client. ▪Multiple Web API Servers can be installed with Web Servers and load-balanced under your load balancing infrastructure when there is a large number of API calls for intensive API triggered diagnosis in large networks. |
Worker Server |
Deploying more Worker Servers is recommended for a large number of back-end network automation tasks, such as network monitoring, path discovery, runbook execution, triggered diagnosis. |
Task Engine |
Supports high availability with active/standby nodes. |
RabbitMQ |
Supports high availability with three nodes. |
Redis |
Supports high availability with master/replica/sentinel nodes. |
MongoDB |
Supports high availability with primary/secondary/arbiter nodes. |
Elasticsearch |
Supports high availability with normal/master-eligible-only nodes. |
Front Server |
Deploying more Front Servers is recommended for a large number of network nodes. Each Front Server is recommended to manage at most 5,000 nodes. |
