NetworkBrain Smart CLI is an SSH and Telnet client for the Windows platform. You can use it integrated with NetworkBrain IE to execute CLI commands or integrate it with NetworkBrain IE to automatically log in to devices, execute CLI commands, compare execution results, and collaborate with others for troubleshooting.
Note: Before using NetworkBrain Smart CLI, you need to install Smart CLI on Windows first.
The following is a recommended flow for using Smart CLI along with NetworkBrain IE:
1.Connect to Devices from NetworkBrain Map.
2.Compare CLI Results with Historical Data to View Changes.
3.Share Findings to Collaborate with Others.
4.Automate Command Execution through Runbook.
