NetworkBrain Inventory Report records comprehensive inventory data of your network, including device data, module data, interface data, site data and more.
You can either use built-in reports as templates to export or customize your own reports by specifying device scope and asset data.
The following types of inventory reports are provided in the system.
Category |
Built-in Reports |
Device Report |
Contains properties of devices in the current domain, such as management IP, device type. |
Interface Report |
Contains the interface properties for all devices in the current domain, such as IPv4/6 address, bandwidth. |
Module Report |
Contains the module properties for all devices in the current domain, such as module ports, slot number. |
Site Report |
Contains the summary information for all sites in the current domain, such as location, device count. |
Summary Report |
Contains the summary information for all devices in the current domain, such as module count, interface count. |
Customized Reports |
Shared Reports |
Visible and editable to all users in the current domain. ▪FRU Report — contains the chassis hardware information about Cisco routers, Cisco IOS switches, Juniper routers and Juniper EX switches in the current domain. ▪Stackable Switch Report — contains the stack information about Cisco Routers or IOS Switches in the current domain. ▪VSS Report — contains VSS modules in the current domain. ▪Router_If_Report — contains the interface properties for routers in the current domain. ▪Switch_If_Report — contains the interface properties for switches in the current domain. ▪Other_If_Report — contains the interface properties for other device types in the current domain. |
Private Reports |
Only accessible to the report author. |
Tip: Qapp Reports are marked with the
icon.
