Guidebook Manager offers a central location where users can manage their saved Guidebooks.
To activate Guidebook manager:
1. Click
in Decision Tree interface.
2.Select Guidebook Manager from the drop-down.
You can view all saved Guidebooks in Guidebook Manager interface, and its respective detailed information:
oGuidebook ID
oGuidebook Name
oDescription
oCreated by
oLast Modified Time
2.In the Create Guidebook window, you can create a Guidebook.
1.Select a Guidebook, right-click or click
2.Click Edit in the drop-down menu.
3.In the Create Guidebook window, you can modify all the settings.
2.Click Delete in the drop-down menu.
3.In the Warning window, click Delete.
Note: The selected Guidebook as well as the respective Hypothesis will be deleted.
2.Click Duplicate in the drop-down menu.
3.In the Create Guidebook window, the current settings will inherit the settings of the selected Guidebook.
2.Click View on Decision Tree to view this Guidebook in Decision Tree.
3.In the Add Target Device window, select the applicable device(s) of the Guidebook as the target device(s) of Decision Tree. The Guidebook will become available in Decision Tree.
Note: The applicable devices are the qualified devices defined by user when creating the Guidebook.
