In the Device Details pane, you can perform the following actions:
▪Browse and export data tables in Current Baseline.
▪Retrieve data tables from the live network. See Retrieving Live Device Data for more details.
▪Compare data tables. See Comparing Historical Device Data for more details.
1.In the Device Details pane, select the Data Tables tab. Only the available data tables for the target device are listed.
Tip: The table types saved in Current Baseline can be customized in a benchmark task. See Benchmark Task Settings for more details.
2.Click your interested table type to browse data in detail.
▪Comparing Historical Device Data
▪Opening the Device Details Pane
