Comparing Historical Device Data
The historical data of the following data types for each device is supported to be compared from the Device Details pane:
Configuration file
Data tables
CLI commands
Comparing a Single Data Type from Device Details Pane
Take configuration file for example:
1.In the Device Details pane, select the Configuration File tab. The full configuration file of the device is displayed by default.
2.Click the icon under the Configuration File tab, and the comparison result displays directly. See Comparing Network Data Changes for more details.
Opening the Device Details Pane
