Calculating Paths Across Hybrid and Multi Cloud
The system supports end-to-end path calculation in hybrid/multi-cloud environment, and you can analyze the traffic flow between two endpoints.
1.Click Path on the search bar.
2.Enter the IP address of endpoint A in the Source field and the IP address of endpoint B in the Destination field.
3.By default, the system calculates two-way paths. To change the path direction, select the icon or the icon.
4.The related gateways will be auto-identified. If a device has multiple gateways, you can select the correct one from the Gateway list.
5.Click Path to start calculating. Then you can view the diagrammed path on the map with a detailed summary log (in the left pane).
Tip: For more information about hybrid/multi-cloud path, please refer to Feature Summary - Public Cloud Support.
Creating Application Path
Your application may consist of web tier/application tier/database tier, therefore you may want to create a application to include multiple paths for different applications. NetworkBrain path browser can help you create applications and include the corresponding paths.
Tip: For more information about how to use the application manager to create and manage paths, please refer to Organizing and Verifying Paths in Application Manager
Tip: For more information about AWS/Azure Application Path, please refer to Feature Summary - Public Cloud Support.
