After calculating a path, you can view the status and result of the path:
▪View Path Result in Path Result Pane
▪View Path Result Details in Path Overview Pane
The Path Result pane shows the status and the traffic information about a path hop by hop.
There are three types of path result status:
▪Succeeded: all full paths are calculated successfully.
▪Failed: all full paths are calculated unsuccessfully.
The traffic information in the Path Result pane includes:
▪The traffic flow diagram of a path from the source to the destination.
▪Path types (including L2 Path, L3 Path, and Overlay Path). A Path may contain several types of paths at a hop. To view the result of a path type, click it to display the corresponding path on the map.
▪Incoming and outgoing traffic interfaces at each hop.
The Path Overview pane shows the details of path results based on the following categories:
▪Full Path: A full path means a complete path from the source to the destination.
▪Segmented Path: A segmented path means the path between the outgoing interface of a device and the incoming interface of the next-hop (L2 or L3) device.
