1.Enter one of the following search terms in the search bar:
dashboard name
device hostname
2.Press the Enter key on your keyboard to start searching. The search results are displayed under the Dashboard group with the matched keyword highlighted.
Files
Using Dashboard to Visualize Multi-Dimensional Data
