The Port to Protocol List records the correlations between port numbers and protocols, which is used to specify protocols and ports when calculating an A-B path.
1.Log in to the Tenant Management page.
2.In the Tenant Management page, select Operations > Misc Configuration. Click the Port to Protocol List tab.
3.Perform the following operations based on your needs.
1)Click Add. 2)In the Add Port to Protocol dialog, enter the protocol name, description, port number, and select the transport protocol from the drop-down list. Tip: To synchronize the added entry with NetBrain Server, select the Auto Update check box. If the system does not support any protocol you want to use, contact NetBrain Support Team to report the issue. 3)Click OK. The new entry is added to the list. |
Click Export to export the list. Tip: The default location of the exported file is C:\Users\<your username>\Downloads. |
