1.In your web browser, navigate to http(s)://<IP address of NetBrain Web Server>/admin.html. For example, https://10.10.3.141/admin.html or http://10.10.3.141/admin.html.
2.In the login page, enter your username or email address, and password. The initial username/password is admin/admin.
Note: If you are using SSO (Single Sign On), click the hyperlink of the SSO server to redirect to the login page of your Identity Provider. After your credentials are verified, you will be directly logged in to the system and you can skip step 3.
3.Click Log In.
▪If you don't have the privileges of the system administrator, the page will be the Tenant Management page.
▪If you have the privileges of the system administrator, the page will be the System Management page. Then go to step 4.
4.In the System Management page, select Operations > Tenant Management to get into the target tenant.
Note: It is not recommended to use the same web browser to log in to the system with multiple user accounts. Only the last logged-in user will be recognized as the current user.
