FID YAML General Information
FID YAML Feature
FID YAML Assets
FID Expression and Function
Qualification Properties and Condition
Action
Define some common parameters for this FID, such as name, description etc.
YAML Sample
version: "1.0"
source: xxxxxxxx # optional, FID source
description: "description......."
tags:
 - BGP
dependencies:
 - Built-in FIDs/FID1
 - Built-in FIDs/FID2
Properties
Property Name
Type
Required
Definition
name
string
Y
Feature name, it is recommended to keep a unique feature name for each feature
version
string
Y
FID YAML structure version number, default value: 1.0
source
string
N
FID source. Default value: NetBrain
description
string
N
Feature descriptions
tags
list
N
Tags of feature
dependencies
list
N
Dependent FID path
FID YAML Feature
Qualification
The FID qualification defines what conditions or criteria that a device should meet to apply the FID on itself. See Qualification Properties and Condition
Regex
The regex defines what match line of the device configuration is true to apply this FID.
Line Pattern (decode)
The line pattern is defined to match the config-line by which decodes the device configuration.
Config line matching logic will follow:
oConfig keyword should be exactly matched.
oFor config variable,
If it is a string variable, it will match any word in the configuration file.
If it is another variable, it should exactly match the variable type in the configuration file.
oIf the line pattern supports fuzzy matching, it can match the configuration line longer than the pattern, as long as it exactly starts with the line pattern.
For example:
Line Pattern
Configuration Line
Result
ip address $ip $ip
ip address 10.10.10.10 255.255.255.0
Match.
ip address $str $ip
Match.
A $str variable in line pattern can match any word in the configuration line.
ip address $str $ip
ip address some-string 255.255.255.0
Match.
ip address $ip $ip
Not match.
The word in line "some-string" is not $ip variable.
ip address $ip $ip
ip address 10.10.10.10 255.255.255.0 secondary
Fuzzy matching.
The first part of config line matches the line pattern. If the line pattern supports fuzzy matching, it is matched.
ip address $ip $ip
Not match.
The configuration line lacks one variable.
ip address $ip
Fuzzy matching.
ip address $ip 255.255.255.0
Match.
The variable instance can also be defined in line pattern.
address $ip
Not match.
YAML Sample
feature:
 qualification:
   conditions:
     - property: driver
       operator: Contains # support types: Contains, Match, NotCotrains, NotMatch
       values: "Cisco"
     - property: device_type
       values:
         - Cisco IOS Switch
         - Cisco Router
     - property: config
       operator: Match # support types: Contains, Match, NotCotrains, NotMatch
       values: "word"
   boolean_expression: (A and B) or C
 configlet: # configlet
   sample: |- #configlet sample, optional
     D1:
     interface Loopback0
      ip address 10.10.10.10 255.255.255.255
     router bgp 1
      bgp log-neighbor-changes
      neighbor 20.20.20.20 remote-as 2
      neighbor 20.20.20.20 update-source Loopback0
     D2:
     interface Loopback0
      ip address 20.20.20.20 255.255.255.255
     router bgp 2
      neighbor 10.10.10.10 remote-as 1
      neighbor 10.10.10.10 update-source Loopback1
      neighbor 10.10.20.10 remote-as 2
      neighbor 10.10.20.10 update-source Loopback2
   match_rules: # Match Rules, if this FID is for multiple devices and the rule are different, here can define multi rules.
     - regexes: # the first rule is the main Match Rule
         condition1: # match condition name, use "or" between multiple conditions, use "and" between multi regex line in one condition
           - regex: standby # regex means is used for single-line matching.
           - mregex: ^interface1 .+\n\s+standby # mregex is used for multi-line matching.
           - mregex: ^interface2 .+\n\s+standby
           - mregex: ^interface3 .+\n\s+standby
         condition2:
           - mregex: ^interface .+\n\s+standby
       patterns: # line patterns to match&decode, optional
         group1: |- # line pattern group name, must be unique.
           interface $str:intfName1
           ip address $ip:ip1 $ip:mask1
         # line pattern format:'flag[flag]+: linePattern', support flags: O:Optional, M:Must to have, F:Fuzzy match, E:Exact match.
         # M and O are mutually exclusive, M is the default, no M and O means Must, both means M.
         # F and E are mutually exclusive, F is the default, no F and E means Fuzzy, both means F.
         # $valueType:varName means a variable, supported value types: str, num, bool, ip, ipv6, mac, time.
         # $varName means a variable, string is the default value type.
         # The variable name must be unique in one configlet.
         # $? means a variable that don't need to use.
         group2: |-
            MF: router bgp $int:bgp
             O: bgp log-neighbor-changes
             F: neighbor $ip:ip2 remote-as $int:remoteBGP
           OE: neighbor $ip:ip3 update-source $str:intfName2
       split_keys: # variable signature concept, optional
         group1: [$intfName1]
         group2: [$bgp, $ip2]
       relation: equals($intfName1, $intfName2) && equals($ip2, $ip3)
       generate_one_FI_groups: ["groupX"]
     - regexes: {} # The following items are other rules, if any.
       patterns: {}
       split_keys: {}
       relation: ""
       generate_one_FI_groups: []
   eigen_variables:
     - name: crossRelationKey
       expression: combine($ip1, $ip2, $bgp, $remoteBGP)
     - name: ip1Subnet
       expression: ($ip1)
     - name: bgp
       expression: $bgp
     - name: subFIDesc
       expression: $device.name + $intfName1 + subnet($ip2)
   commands:
     - show ip route
     - show ip bgp
     - show ip bgp summary
     - show interface {$intfName1}
 cross_relation:
   group_by: $crossRelationKey # only support to use one eigen variable
   qualification: $bgp!=null # optional, The expression used to filter Sub FI
   group_type: Contains # Contains or ExactMatch, the default value is ExactMatch
Properties
Property Name
Type
Required
Definition
qualification
object
N
qualification.condition
list
N
Qualification condition, see Qualification Properties and Condition
qualification.condition.property
enum
N
Qualification condition properties include:
Device Type
Config File
etc.
qualification.condition.operator
enum
N
Qualification condition operator enum includes:
Contains
Match
NotCotrains
NotMatch
qualification.condition.value
string
N
Qualification condition value
qualification.boolean_expression
string
N
Qualification bool expressions such as A AND B OR C
configlet
object
Y
The array of configlet where each configlet object belongs to one device.
configlet.sample
string
N
Feature decode configlet sample
configlet.match_rules
list of object
N
Multiple match rules can be defined here if different devices' rules are different.
The first rule is the main rule, and the following rule will be applied only if its previous one does not match.
If no rule is defined here, you can still use GDR variables to generate eigen variables and commands.
configlet.match_rules.regexes.{condition_name}
list of string
N
Several conditions can be defined here, separated by different condition names. Multiple regexes can be defined in a condition.
The relation within a condition is "OR", while the relation between these conditions are "AND".
The key of each condition is regarded as a condition name, and thus it should be unique under one configlet.
Under each condition, there are two types of matching:
1.regex: single-line matching
2.mregex: multi-line matching
configlet.match_rules.patterns
object
N
Config line patterns can be defined here.
configlet.match_rules.patterns.{group_name}
string
N
Line pattern provides a more specific way to match config lines in the config file, and can also extract variables from these config lines. A sample line pattern will be: M: standby $str:standbyName ip $ip:ip
Variables can be defined in line pattern as"$<variable type>:<variable name>".
There are 7 types of supported variables: str, num, bool, ip, ipv6, mac, time. If not specified, the default variable type is str.
The variable name should be unique within one configlet.
$? means a variable that doesn't need to use. Its type will be str.
Line patterns can be assigned to different groups to distinguish line pattern scope. For instance, group1 may contain HSRP feature defined under an interface, while group2 may contain OSPF global configuration. "group1" and "group2" are group names that should be defined uniquely within a configlet.
configlet.match_rules.split_keys
object
N
A line pattern could match multiple config line instances in the configuration file, and thus some line pattern variables may have multiple possible values. Defining variable here will make sure that the variable only has one instance value in the subFI.
configlet.match_rules.split_keys.{group_name}
list of string
N
List of variables' names in their corresponding pattern group that should be unique in subFI.
configlet.match_rules.generate_one_FI_groups
list of string
N
List of group names.
Opposite to split_keys, some pattern groups could match multiple group instances, but they do not need to be distinguished from each other, such as access-list. In such a case, that pattern group can be defined here to ensure that the pattern group only has one instance across all matched subFI.
configlet.match_rules.relation
string
N
Variable relations can be defined here. All line pattern variables and device GDR can be used here for relation expression, as well as the global functions. Please refer to FID Expression and Functionfor detailed usage of expression.
The output value type of relation expression must be boolean.
eigen_variables
object
N
Eigen variables defined here can further be used in cross_relation and automations.
eigen_variables.name
string
N
Name of eigen variable. It should not be the same as line pattern variables or Expression built-in functions. It should also be unique in all eigen variables defined here.
eigen_variables.expression
string
N
An expression string.
All line pattern variables and device GDR can be used here to generate eigen variables, which can further be used in automations.
commands
list of string
N
The commands used to troubleshoot this feature.
Show commands to troubleshooting this feature. The command can use variables defined in line patterns of the same configlet, which starts with "$". The format follows string Interpolation, e.g.  "show standby { $standbyName1 }". See https://docs.microsoft.com/en-us/dotnet/csharp/language-reference/tokens/interpolated for more about string Interpolation.
If a variable inline pattern matched multiple instances in the config file, each variable value will construct a command. For example, "show standby { $standbyName1 } "uses "standbyName1" defined in line patterns. If "standbyName1" matches value 22, 23 in the config file, the corresponding commands will be "show standby 22" and "show standby 23".
If a device config matches more than one configlet in the same FID, all the commands from these configlets will be merged together.
cross_relation
object
N
The cross relation can be defined here to correlate several devices if they share the same feature needed to be grouped together for troubleshooting.
cross_relation.group_by
string
N
group_by needs to be eigen variable name.
The cross relation logic will use eigen variable defined here to group subFIs from different devices if they are the same value.
cross_relation.qualification
string
N
The qualification used to filter subFI.
see FID Expression and Function
cross_relation.group_type
enum
N
There are two supported group types:
ExactMatch: default.
Contains: Will merge all the subFIs, either from the same device or different devices, if eigen variable in group_by has multiple values.
