Index Store (Elasticsearch index) mechanism is to support more tenant data, and keeps search performance intact in the case of a large number of tenant/domains.
1.Login to System Management Page.
2. Select Operations > Index Manager from the quick access toolbar.
3.Click Add on the Index Manager tab.
4.In the Add Index Store window, define the store name, unique key and description.
Field |
Data Type |
Comments |
Store Name |
String |
The name of the index store |
Unique Key |
String |
The unique identifier of each index model as to create a unique index in the database |
String |
Description for the index store |
5.Click OK.
1.Login to the System Management page.
2.In the System Management page, select the Tenants tab and click Add.
3.Select the desired store in the Add Tenant window.
Note: By default, the data is stored in the default store.
