The more automation tasks the system performs, the more data will be retrieved and generated. Generally, the data includes the following two types:
▪Device data, such as configuration files, route tables, original CLI data, golden baseline data and parser data.
▪Task data, such as Qapp/Gapp execution logs, benchmark/discovery execution logs, One-IP table entries and so on.
The system provides the definitions of auto-clean rules for the above two types of data at the domain level. The default settings are as follows:
To customize the auto-clean rules for your domain data, do the following:
2.In the Domain Management page, select Operations > Domain Settings > Global Data Clean Settings from the quick access toolbar.
3.On the Global Data Clean Settings tab, make modifications based on your needs.
Category |
Default Auto-Clean Rule |
Data Engine Data |
For data older than 4 months, only keep 2 data points for each data type in a month. Note: The number of months must be between 0 and 65535. If you enter 0, the system will only keep the data in the current month and delete all aged data. |
Delete data older than 6 months Note: The number of months must be between 0 and 65535. If you enter 0, the system will only keep the data in the current month and delete all aged data. |
Other Data |
Qapp/Gapp Execution Logs |
Delete data older than 14 days |
One-IP Table Entries |
Delete data older than 14 days Note: You need to enable Build L2 Topology in your scheduled benchmark, or manually rebuild the L2 Topology. After the execution of the benchmark task, the settings in One-IP Table Entries will take affect. |
Discovery/Benchmark Logs |
Application Path History Data |
Delete data older than 6 months |
Data Unit Storage |
Delete data older than 1 months |
Backup Maps |
API Triggered Automation Task |
Triggered Incidents |
Event Entries in Event Console |
Execution Logs for Scheduled Data View Template & Parser Tasks |
Dashboard Activity Table |
Compare Results |
Third Party Flash Alert |
Delete data older than 3 months |
Feature Intent Template Execution Logs |
Adaptive Polling Result and Flash Alert |
4.Click Save.
▪Managing MongoDB Disk Alert Rules
