Basic Parser Rules for Parser Group
The system provides four types of parser rules that can be applied to a parser or a parser group.
Single-line Rule
Text Replacement
Start Line
End Line
Example for Basic Parser Rules
The definition of the following paragraph parser shows the four basic parser rules, including text replacement, start line, single line rule and end line.
