The ‘Apply to Other Automation’ function can be used to bulk install multiple automations.
1.Click
,scroll down and select Proactive Automation Manager from the menu.
2.Navigate to Triggered Automation tab or Recommended Automation tab.
3.Select the desired automation, in Last Modified Time column, click
4.Apply to Other Automation
oApply to Triggered Automation
oApply to Recommended Automation
1.Select Apply to other Network Intent.
2.Select the desired Network Intent and click OK.
•If clicking Apply to CLI Command, enter the command, and click Add.
•If clicking Apply to Runbook Template, select the desired Runbook Template, and click OK in the pop-up window.
•If clicking Apply to Network Intent, select the desired Network Intent, and click OK.
Note: The bulk applied automations will inherit the Flash Probe or Hypothesis settings from the selected installed automation.
