R11.0a-March2023
Schedule Cisco Support Information Plugin
Follow the steps to schedule the Cisco SNTC plugin to collect SNTC data:
  1. On the Domain Management page, open Schedule Task.
  2. Select Schedule Discovery/Benchmark.
  3. Click Add Benchmark Task.
  4. Specify Task Name e.g. Cisco SNTC V3 task.
  5. Setup Frequency e.g., Weekly.
  6. Check Device Group in Device Scope.
  7. Select a device group for all supported Cisco devices. All supported cisco device types are listed.
  8. Uncheck all the data types in Retrieve Live Data.
  9. Skip the CLI Commands and Additional Operations after Benchmark tabs, Go to the Plugins tab.
  10. In the Plugins Tab, click Add Plugin in the first Execution Point and select Special_Scenarios/Cisco_support_Information/Cisco_Support_Information.
  11. Review Summary and click Submit.
Cisco WLC
Cisco IOS XR
Cisco Nexus Switch
Cisco ASA Firewall
Cisco WAAS
Cisco Router
Cisco Voice Gateway
Cisco IOS Switch
Cisco ACE Load Balancer
Cisco Meraki Switch
Cisco Firepower NGFW with FTD
Troubleshooting
If there are any problems encountered during the deployment or integration of NetBrain with Cisco SNTC, contact NetBrain Support at [email protected].
