R11.0a-March2023
Create Parser
The Parser is the foundation of many automation objects, such as Qapp, NI, DVT, etc. The Parser parses the variables you are interested in from the CLI command output, configurations, or API output.
The v10.0 adds the Visual Parser to allow users to create a Parser with no or little codes. The Paser in the prior versions is renamed as Advanced Parser.
Differences between Visual Parser and Advanced Parser
The following table lists the feature comparison between the visual Parser and advanced Parser:
Feature Category
Visual Parser
Advanced Parser
Start/End Line
Text Replacement
Real-time highlight variable definition and comment
Line pattern syntax highlight and intellisense
Paragraph nested table √
Paragraph nested paragraphMulti-level nesting with parent lineMulti-level nesting
Supported Line Pattern Syntax
  • Simple line pattern
  • mline
  • regex
  • mregex
  • regex
  • mregex
Supported variable types
  • string
  • mstring
  • int
  • float/double
  • bool
  • enumeration
  • dummy
  • string
  • int
  • double
  • bool
  • enumeration
  • dummy
Allowed ID linesMultiple ID linesOnly one ID line
Supported Parser Type
  • Text
  • Variable (keyword)
  • Paragraph
  • Table
  • Collector
  • Paragraph
  • Table
  • Filter
  • Script
Supported Data Type
  • CLI
  • SNMP
  • Configuration
  • CLI
  • Configuration
  • SNMP
  • API
Allowed SamplesOne sample onlyMultiple samples
You can manage Parsers with  Parser Library.
