Create and Run Selected Intent
You can create an intent instance based on the selected NITs by clicking the Create Intent (or Recreate Intent if an intent was created) button in the Selected pane, then run and view the results.
Create Intent
Create Intent: If it is the first time an intent is created, the Create Intent button is displayed.
Recreate Intent: Click Recreate Intent to recreate intent. If an intent has been created before and the current selection is different from the previous selection, the Create Intent Button will automatically change to Recreate Intent Button, and a red dot will show up to remind users to recreate the intent.
Execute Intent and View Results
After an intent is created/recreated, you will be directed to the Run Intent pane, where execution results are displayed. You can go through the results and click Run to re-run the intent for troubleshooting. The running setting can be configured by clicking the setting icon next to the Run button.
Tip: If the created intent has been executed several times, select a history record to view the corresponding execution outputs.
The results can be viewed in the post-execution Diagnosis Tree or the Map.
- View results in the post-execution Diagnosis Tree.
- View results on the map by clicking the
icon.
