Built-in Plugin
The Plugin function aims to correct or fix up the inaccurate data and topology model calculated by the system. A Plugin is essentially a set of Python scripts that can be executed in the system for data acquisition, update, and revision.
Plugin Name | Purpose | Execution Point | ||||
Import Config | To add devices and device interfaces to the system.
| Before executing a discovery task | ||||
Import End System | To add end systems to the system and set path their gateways for path calculation.
Topology Stitching | To modify the topology links between device interfaces. This plugin can be added to a benchmark task at the execution point after building L3 topology.
| After building L3 topology | ||||
Checkpoint Warp Topology Stitching | To establish the IPv4 L3 topology for Checkpoint virtual system and Checkpoint virtual router/virtual switch. This plugin can be added to a benchmark task at the execution point after building L3 topology. | After building L3 topology | ||||
Identify Management Interfaces | To identify the management interface of each device and update the corresponding interface property. This successful execution of this plugin ensures the Exclude Management Interface option in the Map Settings can function well.
| After rebuilding Visual Space | ||||
Separate ASA Firewall Failover Interfaces into Different Zones | To add failover interfaces of ASA Firewalls with the same IP addresses to different zones so that the failover interfaces can participate in L3 topology calculation. This plugin can be added to a benchmark task at the execution point before building the network’s L3 topology. | Before building L3 topology | ||||
Separate Checkpoint Firewall Sync Interfaces into Different Zones | To add the sync interfaces of Checkpoint firewalls with the same IP addresses to different zones so that the sync interfaces can participate in L3 topology calculation. This plugin can be added to a benchmark task at the execution point before building the network’s L3 topology. | Before building L3 topology | ||||
SRX_Remove_Superfluous_Interfaces | To customize the L2 topology to connect neighbor interfaces with SRX firewalls that are configured as a chassis cluster. This plugin can be added to a benchmark task at the execution point after building L3 topology. | After building L3 topology |
