2023-Nov-03-R11.1a
View Path Results and Details
After calculating a path, you can view the status and result of the path:
Viewing Path Result in Path Result Pane
The Path Result pane shows the status, the traffic information, and Technology Tag about a path hop by hop.
Path Status
There are two types of path result status:
- Succeeded: All full paths are calculated successfully.
- Failed: All full paths are calculated unsuccessfully.
Traffic Information
The traffic information in the Path Result pane includes:
- The traffic flow diagram of a path from the source to the destination.
- Path types (including L2 Path, L3 Path, and Overlay Path). A Path may contain several types of paths at a hop. To view the result of a path type, click it to display the corresponding path on the map.
- Incoming and outgoing traffic interfaces at each hop.
Technology Tag
The Technology Tags show the network technology checked by the path discovery logic.
Viewing Path Result Details in Path Details Pane
The Path Details pane shows the details of path results based on the following categories:
- Path Logic Pane: Show the data used in Path Discovery, including the device information, the interface information, and the execution log (which is fully displayed). You can write notes for each path hop.
- Path NI Pane: You can define Path NI, execute Path NI, and view its results.
