2023-Nov-03-R11.1a
Gapp Center
Gapp Center is a self-contained manager that provides you with a comprehensive view of all accessible Gapp files.
- Built-in Gapps — contains the pre-installed Gapps. This category is accessible to all users but can only be modified by system administrators.
- Shared Gapps in Tenant — contains Gapps that are accessible to all users in this tenant.
- My Gapps — contains Gapps that are only accessible to yourself. You can find your private Gapps in all accessible domains under one tenant.
Working with Gapp Center
- Click the start menu
and select Gapp Center. - Point to a Gapp file and click the
icon to preview it.
Note: You can also right-click a Gapp and select Run it as a Runbook node.
