2023-Nov-03-R11.1a
Authorizing Users to Create Domains
System admin can authorize the privilege of creating domains for a user account when adding it to the system, or later.
To authorize the privilege at a later time:
- Log in to Tenant Management Page.
- On the User Authorization tab, select or deselect the check box under the Allowed to create domain column for the target user.
