Built-in Device Properties
The following table lists the device properties/attributes (case-sensitive).
| Property/Attribute Name | Description |
| name | The hostname of a device. |
| mgmtIP | The management IP of a device. |
| subTypeName | The device type of a device. |
| mgmtIntf | The management interface of a device. |
| vendor | The vendor information about a device. |
| model | The model information about a device. |
| ver | The version of a device. |
| sn | The serial number of a device. |
| site | The site that a device belongs to. |
| loc | The location of a device. |
| contact | The contact person of a device. |
| mem | The system memory size of a device. |
| assetTag | The asset tag of a device. |
| layer | The network layer that a device belongs to. |
| descr | The description of a device. |
| oid | The system object ID of a device. |
| driverName | The driver that a device uses. |
| assignTags | The tag assigned to a device for applying the network-based layout style on a map. |
| hasBGPConfig | Indicate whether a device has been configured with the BGP protocol. |
| hasOSPFConfig | Indicate whether a device has been configured with the OSPF protocol. |
| hasEIGRPConfig | Indicate whether a device has been configured with the EIGRP protocol. |
| hasISISConfig | Indicate whether a device has been configured with the IS-IS protocol. |
| hasMulticastConfig | Indicate whether a device has been configured with the Multicast protocol. |
| mgmtMAC | The management MAC of a device. |
| lwap_defaultGW | The default gateway of an LWAP device. |
| lwap_group | The group that an LWAP device belongs to. |
| lwap_priCntrllr | The primary controller of an LWAP device. |
| lwap_secCntrllr | The second controller of an LWAP device. |
Note: To check more built-in device properties, navigate to Tenant Management page > GDR Data Configuration > Device Properties tab. |
Built-in Interface Properties
The following table lists the interface properties/attributes (case-sensitive).
| Property Name | Description |
| name | The name of an interface. |
| ips | The IPv4 address of an interface. |
| ipv6s | The IPv6 address of an interface. |
| ipv6LinkLocalAddress | The IPv6 local address of an interface. |
| mibIndex | The MIB index of an interface. |
| bandwidth | The bandwidth of an interface. |
| speed | The speed of an interface. |
| duplex | The duplex of an interface. |
| intfStatus | The state of an interface. |
| macAddr | The MAC address of an interface. |
| moduleSlot | The module slot number of an interface. |
| moduleType | The module type of an interface. |
| descr | The description of an interface. |
| routingProtocol | The routing protocol configured on an interface. |
| multicastMode | The multicasting mode of an interface. |
| mplsVrf | The name of the VRF configured on an interface. |
| mplsVpn | The MPLS VPN configured on an interface. |
| inAclName | The inbound ACL of an interface. |
| outAclName | The outbound ACL of an interface. |
| mode | The switch port mode of an interface. |
| vlan | The VLAN number that an interface belongs to. |
| trunkNativeVlan | The native VLAN of an interface as switch port. |
| trunkEncapsulation | The trunk encapsulation protocol of an interface as a trunk port. |
| ipUnnumberedIp | The unnumbered IP address of an interface as an unnumbered interface. |
Note: To check more built-in interface properties, navigate to Tenant Management page > GDR Data Configuration > Interface Properties tab.
Built-in Module Properties
The following table lists the module properties (case-sensitive).
| name | The modules of a device. |
| type | The port counts of a module. |
| ports | The module type of a module. |
| sn | The serial number of a module. |
| hwrev | The hardware revision of a module. |
| fwrev | The firmware revision of a module. |
| swrev | The software revision of a module. |
| descr | The description of a module. |
Note: To check more built-in module properties, navigate to Tenant Management page > GDR Data Configuration > Module Properties tab.
