Visualize the Solarwinds Data with DVT
Use Case
Using the publicly available Solarwinds Orion SDK, NetBrain has created an integration compatible with NetBrain release 8.0 (and newer) that enables a NetBrain administrator to overlay the Solarwinds device and interface monitoring data on user-created maps.
With this integration, NetBrain can overlay the following extended information as attributes. Device level:
- CPU Load% (Map URL to Solarwinds device details)
- Memory Used %
- System Uptime
- SysLog messages
Following data is seen on the interface level:
- Utilization In %
- Utilization Out %
- In Discards This Hour
- Out Discards This Hour
- In Errors This Today
- Out Errors This Today
- CRC Align Errors Today
- MTU
Note: This solution makes queries to SolarWinds based on the device hostname as the primary key. NetBrain device hostname and SolarWinds hostname must be identical to make this solution function. |
NetBrain Map with Solarwinds Data Overlay
Below are two example representations of the Solarwinds data overlay on devices and interfaces.
