Viewing and Understanding Execution Tree
Opening Execution Tree
- Go to
on the desktop and search Preventive Automation Console, select the option from the results to open it.
Click a device in the device list, and the Execution Tree will be activated.
Note: The Execution Tree displays the preventive automation details of the selected device.
Tip: To view the Execution Tree side by side with the map, you can click to hide the PA dashboard.
- The Execution Tree will demonstrate all the probes and triggered intents for the selected device.
- The lower window shows the alert history during the selected time range.
| # | Meaning |
| 1 | You can select the latest or the historical execution results of the probe from the drop-down menu. |
| 2 | The tags of the network intent can be used to narrow down to the interested network intents. |
| 3 | You can quickly switch between different devices by using the drop-down menu. |
Tip: You can click on the probe icon and network intents on the Execution Tree, and the results in the Alert History window will be filtered based on your selection. |
See Also:
