View Meraki Network by MERAKI Teleworker
To view details of Meraki MX and Meraki Z3, you can navigate directly to MERAKI Teleworker view. To view the details of a node, proceed with the following steps:
- Select Network in the left pane of your NetBrain desktop.
- In the Network pane, select MERAKI in the Category field.
- In the View field, select MERAKI Teleworker.
- Expand the MERAKI MX node to view more information.
Tip: The number next to each node indicates the number of its child nodes. - Click Device Details pane to view the node’s detailed property, interface, and IP interfaces.
