Use Case 2: Retrieve Data from ADT
After an ADT view is added to TAF Lite, any cell data can be retrieved and returned to the 3rd-part system via API call.
API Parameters
To locate and retrieve data from a specific cell, the API is required to include a column name and a rule to filter out row names.
Tip: If no rule is defined to filter out the rows, data from all rows in the column will be returned to the 3rd-party system. |
- API URL: API/V3/TAF/Lite/adt/data
- Description: The API is for retrieving ADT data.
Input Parameters:
Parameter Type Required Description endpoint string Yes The endpoint generated by the system when users add an ADT view to TAF Lite. passKey string Yes To authenticate the access to the ADT view. filterDevices array No A list of device names to filter out rows in the ADT view.
Define a list of device names. A row matches if the device name in the device column is in the list.
columns array No To define the returned columns, users need to fill in the display name list for the column.
When the value is empty, all columns will be returned.
Optional Parameters for Advanced Settings
Parameter Type Required Description option.rowFilter object No columnName: value
Multiple values are combined using AND logic.
pageSize int No The count of returned entries. The default value is 100. pageNumber int No The count of returned pages. The default value is 1.
Sample Request:
Response
The table includes what data can be retrieved by API and how the data will be returned.
| ADT Column Type | Return |
| device |
| device list |
device name1 device name2 |
| interface |
device - interface name
| interface list |
device - interface name1 device - interface name2 |
| string | string |
| int | string |
| float | string |
| bool | string (True/False) |
| map |
| time | 4/25/2024 10:00:13 PM, UTC 5 |
| intent |
| intent result summary |
(m) alert, (n) success
| intent status code summary |
1st message | number
| path |
| site |
| ADT Dataset | [device], [cmd list/config], [timestamp] |
