Test Parser
You can use Test Parser feature to ensure the parser can work as expected not only on the current device, but also on other devices before being used in other automation features, such as Intent/Intent Template, Preventive Automation, Runbook CLI node, etc., to increase the successful rates of these automations.
After the test, you can identify the gaps in the parser definition and fix the parser issue based on the testing results and logs.
Use Flow
  1. Specify testing devices: which devices to be tested.
  2. Specify data source and retrieve data: where the data for parsing comes from.
  3. Run the test and view the results.
If any error occurs in the test results, resolve the errors and test again.
