Search for Paths
- Enter one of the following search terms in the search bar:
- Path name, application name
- Source, destination
- IP address or hostname of hop device
Note: When an IP address is entered in the source or destination field, you can perform a search using the associated device name as long as the IP address corresponds to a device within the domain.
- Press the Enter key on your keyboard to start searching. The search results are displayed with the matched keyword highlighted.
- Right-click the target path entry and then select Draw Path on Map.
Note: You can also hover over the path in the IntelliSense and click Map to map the path directly.
Note: If the path has not been calculated, the map will be blank.
