Search for Automation Assets
You can search for automation assets, such as Qapp, Gapp, Runbook Template, Data View Template and Guidebook in the Search bar. All the matched Qapp, Gapp, Runbook Template, Data View Template and Guidebook will be centrally displayed in the search results pane.
Note: The NetBrain System supports fuzzy search for automation assets. |
The following table list the properties supported to search for Automation Assets:
| Automation Assets | Search with name | Search with description | Search with tag | Search with ID |
| Qapp | ✓ | ✓ | ||
| Gapp | ✓ | ✓ | ||
| Runbook Template (RBT) | ✓ | ✓ | ✓ | |
| Data View Template (DVT) | ✓ | ✓ | ✓ | |
| Guidebook | ✓ | ✓ | ✓ |
