Search for NCT (Network Control Table)
The current system supports searching Virtual Server tables, and NAT (Network Address Translation) tables.
- Enter one of the following search terms in the search bar:
Column value
Note: The "search NCT" does not support searching by NCT table name and column name; it only supports searching by column values.
IP address
Note: If you search NCTs with an IP address, fuzzy search is supported. You do not have to enter the entire IP address.
Press the Enter key on your keyboard to start searching. The search results are displayed with the matched keyword highlighted.
Note: The search results are listed under the NCT category.
- To open the table, click the See Whole Table link in the upper-right part of the table. The opened table will remember the search keyword, so by default, it will show records that fit the keyword.
Due to the different search approaches, the global search may occasionally return results that are different from the results from "See Whole Table" function. This variation depends on the specific search terms used.
