Search Devices by Formula
Search Devices by Formula allows you to build complex search queries to search for devices by using multiple search criteria and a Boolean expression.
Using Search Devices by Formula
- Click the search bar and then select Search Devices by Formula from the drop-down list.
- Specify the scope to search for devices.
- Set search criteria A based on your needs:
- Select a data source and a property from the first drop-down menu.
- Select an operator from the second drop-down menu.
- Specify the value of the property that you selected.
- Repeat to set more conditions if required.
- Define the condition combination in the Boolean Expression field. For example, A and B.
In the Search Devices by Formula window, four match operators are available:
- Contains: The entered value is part of the contents in the first drop-down menu.
- Does not contain: The entered value is not part of the content in the first drop-down menu.
- Matches: The content in the first drop-down menu is complete the same as the specified value.
- Does not match: The content in the first drop-down menu is not complete the same as the specified value.
Note: When you select Hostname as data source from the first drop-down list, the system supports the Hostname Matches + regular expressions. See Regex Search for more details.
Note : When you select Config File as data source, and Matches as the operator, the system supports "Matches Near", to better match two keywords separated by other words.
5. Click Search. The searched result is displayed as follows:
Components for Search Devices by Formula
The following table lists the available components in a Search Devices by Formula.
| Component | Description | Option Values | ||
| Search Scope | The scope of devices. |
| Search Criteria | Property |
| Match Operator | Specify multiple values by separating them with a semicolon (;).
| Boolean Expression | The logical relationships among search criteria. |
