Modify Guidebook
Functions related to Guidebook Modification:
  • Edit Hypothesis
  • Remove Hypothesis
  • Modify Note
  • Remove Runbook Template and Network Intent
  • Remove Data View Template
  • Modify Guidebook
  • Edit Hypothesis
    1. In Create Guidebook or Edit Guidebook interface, mouse over a Hypothesis.
    2. Click , then you can modify the hypothesis.
    Remove Hypothesis
    1. In Create Guidebook or Edit Guidebook interface, mouse over a Hypothesis and click .
    2. Click Remove in the Warning window.
      Information Note: The Hypothesis and its associated Runbook Template/Network Intent will be deleted from this Guidebook.
    Modify Note
    1. In Create Guidebook or Edit Guidebook interface, mouse over the note and click .
    2. Edit the note inline.
    Remove Runbook Template, Network Intent and Network Intent Cluster
    The Runbook Template, Network Intent and Network Intent Cluster associated with the hypothesis can be removed from a Guidebook.
    1. In Create Guidebook or Edit Guidebook interface, mouse over a Runbook Template/Network Intent/Network Intent Cluster, and click .
    2. Click Remove in the Warning pop-up window. The Runbook Template, Network Intent or Network Intent Cluster will be removed from this Guidebook.
    1. In Create Guidebook or Edit Guidebook interface, mouse over the Data View Template, and click .
      Information Note: The Data View Template and its respective Runbook Template/Network Intent will be deleted from this Guidebook.
    Modify Guidebook
    1. In the Guidebook interface, click the current Guidebook.
    2. In the select Guidebook drop-down list, hover over the intended Guidebook and click .
